Hello, I was using devcloud on my vsCode when I was disconnected. When I tried to connect again I got this error:
ssh: connect to host devcloud.intel.com port 22: Connection timed out
kex_exchange_identification: Connection closed by remote host
I have not changed anything in my authentication key, does it become obsolete after some time? If the problem is with her, how can I update? Just update the "devcloud-acess-key ..." txt file inside my ssh folder?
Thanks!!
I tried on several computers and browsers to access a restricted area to check my key, but I'm having difficulties, giving the error
Bad Request
The connection to the database failed !!
Are you having any instability or is it my problem?
Problem solved, I managed to access.
Thanks!
Thanks for posting in Intel Forum. Glad to know that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored
Thanks and Regards,
Rahul
