Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1467 Discussions
Problem with qsub
ghnunes
Hi, my qsub isn't returning the exec_host, I'm running these commands:
ssh devcloud
qsub JobFile.txt (has a sleep)
qstat -xf xxxx.v-qsvr-1.aidevcloud
the return doesn't have the exec_host, it started from nothing and it's been persisting for more than a day.
When you have run qsub -I it gives this error:
qsub: submission error (maximum number of jobs already queued for MSG user = total number of jobs for current user exceeds queue limit: user xxxx@login-2.aidevcloud, queue batch)
Can you help me ?
RaviranjanK_Intel
If the job is in queue status, exec_host will be not shown.
It will only shown if the job is in the running state.
You can see the exec_host by using following command.
qstat -xf xxxx.v-qsvr-1.aidevcloud | grep exec
Please note that the job should be in running state.
We are attaching the screenshot(image.png),showing result of the above mentioned command for job with both running and queue status.
Hope this helps, if you have any further issue please let us know.
with regards
Raviranjan
ghnunes
Hi @RaviranjanK_Intel , thanks for your help.
Sorry, I do not understand. I ran this command you sent me, but it didn't return anything (qstat -xf xxxx.v-qsvr-1.aidevcloud | grep exec)
I'm still not getting my exec_host, and I'm running the commands suggested to me here (https://community.intel.com/t5/Intel-DevCloud/Problem-with-disconnect/m-p/1313056#M2882)
ssh devcloud
qsub JobFile.txt
It does not return the exec_host to me, and before it returns, following the same commands. It stopped working out of nowhere.
ghnunes
I got access, just to see if I understood.
I ran the qstat command and got a job that was already prepared. Before I wasn't getting it because I was getting one that was still in the queue?
RaviranjanK_Intel
"I ran the qstat command and got a job that was already prepared." could you please elaborate more on this?
Are you able to get the exec_host now or still having the same issue in getting exec_host?
"Before I wasn't getting it because I was getting one that was still in the queue?" yes you are right. You won't be able to see the exec_host if the job is in queue state. The job needs to be in running state.
If you are still facing the issue in getting the exec_host, please share the screenshots of qstat command.
RaviranjanK_Intel
we have not heard back from you. could you please give us an update?
RaviranjanK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
ghnunes
Hi @RaviranjanK_Intel , sorry, forgot to answer, everything worked out, thank you so much for your help!
