Hi guys. I'm trying to run a public container imported from Docker Hub on Container Playground: laffin/cloudproxy:latest.
I want to run this container to deploy cloud instances that will work as proxies and get IP addresses in order to scrape websites without restriction. But after launching the container I get these error in the logs:
2022-03-10 17:48:46.191 | INFO | cloudproxy.providers.manager:init_schedule:37 - DigitalOcean not enabled
2022-03-10 17:48:46.218 | INFO | cloudproxy.providers.manager:init_schedule:49 - Hetzner not enabled
2022-03-10 17:48:46.218 | INFO | cloudproxy.providers.manager:init_schedule:45 - GCP not enabled
self._file = open(path, **self._kwargs)
File "/usr/local/lib/python3.8/site-packages/loguru/_logger.py", line 762, in add
Traceback (most recent call last):
PermissionError: [Errno 13] Permission denied: '/app/cloudproxy.log'
File "/usr/local/lib/python3.8/site-packages/loguru/_file_sink.py", line 187, in _initialize_file
self._initialize_file()
wrapped_sink = FileSink(path, **kwargs)
logger.add("cloudproxy.log", rotation="20 MB")
File "/usr/local/lib/python3.8/site-packages/loguru/_file_sink.py", line 167, in __init__
File "./cloudproxy/main.py", line 36, in <module>
2022-03-10 17:48:58.927 | INFO | cloudproxy.providers.manager:init_schedule:37 - DigitalOcean not enabled
2022-03-10 17:48:58.957 | INFO | cloudproxy.providers.manager:init_schedule:45 - GCP not enabled
2022-03-10 17:48:58.957 | INFO | cloudproxy.providers.manager:init_schedule:49 - Hetzner not enabled
2022-03-10 17:49:25.891 | INFO | cloudproxy.providers.manager:init_schedule:37 - DigitalOcean not enabled
2022-03-10 17:49:25.920 | INFO | cloudproxy.providers.manager:init_schedule:49 - Hetzner not enabled
2022-03-10 17:49:25.920 | INFO | cloudproxy.providers.manager:init_schedule:45 - GCP not enabled
Looks like there are some permissions denials but I don't get it well. I added port configuration (8000) and some environment variables. What could be wrong?
Not at this moment. There are no permissions, you can only run the provided samples as they are right now. However, as I mentioned, that should be changing very soon.
Chris
Container playground has not been opened up to allow you to bring your own code in. That is a feature that is coming, hopefully very soon.
Chris
Hi @ChrisB_Intel , thanks for your answer. Thought I could import public containers from Docker Hub. Isn't it true then? Where can I read more about permissions? I couldn't find them in the documentation.
Chris
