Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1472 Discussions
Question about submitting job
Gao__Chao
I want o to submit two queues that run separately on GPU and FPGA in one CPP file to a node contains both GPU and FPGA?
More specifically, how we write q sub?
Chao
AthiraM_Intel
In DevCloud, GPU and FPGA are not available in same node. They are present in separate nodes.
If you have any further issues please let us know.
Gao__Chao
I see, but I was also wondering what inside of a single node?
Is there any high-level architecture?
Chao
AthiraM_Intel
You could find the architecture and features of the compute nodes available by using the below command in login node:
pbsnodes
Please find the screenshot, which shows the details of a specific compute node. Here you can see that this particular node is fpga node.
Similarly you will be able to find the details of all the compute nodes by using the pbsnodes command.
AthiraM_Intel
Could you please give us an update? Has the solution provided helped?
AthiraM_Intel
We have not heard back from you, we wont be monitoring this thread. If you need further assistance, please post a new thread.
