Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1660 Discussions
Re: Re:FPGA Builds Broken on DevCloud
filipeborralho
Hi @AlekhyaV_Intel ,
I'll have to write down here because for some reason I'm getting some error when attaching my cpp file. The Makefile is attached.
#include <vector>
#include <CL/sycl.hpp>
#include <sycl/ext/intel/fpga_extensions.hpp>
#include "dpc_common.hpp"
typedef std::vector<float, cl::sycl::usm_allocator<float, cl::sycl::usm::alloc::shared> > floatVec;
void compute (cl::sycl::queue &q, floatVec &A);
int main (int argc, char **argv) {
    try {
        cl::sycl::ext::intel::fpga_selector s;
        cl::sycl::device d(s);
        cl::sycl::queue q(d, cl::sycl::property::queue::enable_profiling{});
        cl::sycl::usm_allocator<float, cl::sycl::usm::alloc::shared> myFloatAlloc(q);
        floatVec A(3, 0.5f, myFloatAlloc);
        std::cout << "Before compute: " << A.at(2) << std::endl;
        compute(q, A);
        std::cout << "After compute: " << A.at(2) << std::endl;
    } catch (cl::sycl::exception const &e) {
        std::cout << "Exception caught.\n" << e.what() << std::endl;
    return 0;
void compute (cl::sycl::queue &q, floatVec &A) {
    auto acc { A.data() };
    cl::sycl::event e {
        q.submit([&](cl::sycl::handler &h) {
            h.single_task([=]() [[intel::kernel_args_restrict, intel::max_global_work_dim(0)]] {
                acc[2] += acc[1] * acc[0];
    q.wait();
    const auto start { e.template get_profiling_info<cl::sycl::info::event_profiling::command_start>() };
    const auto end { e.template get_profiling_info<cl::sycl::info::event_profiling::command_end>() };
    std::cout << "Execution time: " << (end - start) / 1e6 << std::endl;
Filipe
AlekhyaV_Intel
Hi @filipeborralho ,
Thank you for posting in Intel Communities. We have moved your response as a new case to assist you better. We will work on this issue and will get back to you soon. Meanwhile, could you please let us know the nodes on which you've tried compiling and running your sample?
Alekhya
filipeborralho
I believe I am having the same issue as in thread https://community.intel.com/t5/Intel-DevCloud/Re-FPGA-Builds-Broken-on-DevCloud/m-p/1470605#M7819 .
I was using fpga_compile nodes for hardware generation as this was the previous procedure.
fpga_runtime nodes for running the executables
I will try the solution given in the aforementioned thread in the meanwhile.
Filipe
AlekhyaV_Intel
Yes you could follow the steps that I mentioned in the other thread. fpga_compile nodes are used for FPGA report generation, emulation, runtime. You must use Arria10 and Stratix10 nodes to build fpga sample. Please let us know if this resolves your issue so that we can discontinue monitoring this thread.
Alekhya
filipeborralho
Update:
I kept trying other kernels and there still seems to be some kind of problem.
I attached the terminal output and the Makefile.
This is my code:
#include <iostream>
#include <fstream>
#include <string>
#include <vector>
typedef std::vector<int> intVec;
typedef std::vector<float> floatVec;
constexpr auto name { "nell-2.tns" };
constexpr auto nnz { 76879419 };
constexpr auto dim0 { 12092 };
constexpr auto dim1 { 9184 };
constexpr auto dim2 { 28818 };
constexpr auto colCnt { 8 };
void read3Dtensor (intVec &slcIdx, intVec &slcPtr, intVec &fbrIdx, intVec &fbrPtr, intVec &kIdx, floatVec &values);
void computeTTM (cl::sycl::queue &q, const intVec fbrPtr, const intVec kIdx, const floatVec values, const floatVec matrix, floatVec &output);
    try {
        //cl::sycl::ext::intel::fpga_emulator_selector selector;
        cl::sycl::ext::intel::fpga_selector selector;
        cl::sycl::device d(selector);
        intVec slcIdx, slcPtr, fbrIdx, fbrPtr, kIdx(nnz);
        floatVec values(nnz), matrix(dim2 * colCnt, 0.23f);
        read3Dtensor(slcIdx, slcPtr, fbrIdx, fbrPtr, kIdx, values);
        floatVec output(fbrIdx.size() * colCnt);
        computeTTM(q, fbrPtr, kIdx, values, matrix, output);
        std::cout << e.what() << std::endl;
        return 0;
    return 0;
void read3Dtensor (intVec &slcIdx, intVec &slcPtr, intVec &fbrIdx, intVec &fbrPtr, intVec &kIdx, floatVec &values) {
    std::ifstream tensorFile(name);
    int i, j;
    for (auto k { 0 }; k < nnz; ++k) {
        tensorFile >> i >> j;
        if (slcIdx.empty() || slcIdx.back() != i) {
            slcIdx.push_back(i);
            slcPtr.push_back(fbrIdx.size());
            fbrIdx.push_back(j);
            fbrPtr.push_back(k);
        } else if (fbrIdx.back() != j) {
        tensorFile >> kIdx[k] >> values[k];
    fbrPtr.push_back(nnz);
    tensorFile.close();
void computeTTM (cl::sycl::queue &q, const intVec fbrPtr, const intVec kIdx, const floatVec values, const floatVec matrix, floatVec &output) {
    const auto fbrCnt { fbrPtr.size() - 1 };
    cl::sycl::buffer fbrPtrBuffer(fbrPtr);
    cl::sycl::buffer kIdxBuffer(kIdx);
    cl::sycl::buffer valuesBuffer(values);
    cl::sycl::buffer matrixBuffer(matrix);
    cl::sycl::buffer outputBuffer(output);
    cl::sycl::event e {
            cl::sycl::accessor accFbrPtr(fbrPtrBuffer, h, cl::sycl::read_only);
            cl::sycl::accessor accKIdx(kIdxBuffer, h, cl::sycl::read_only);
            cl::sycl::accessor accValues(valuesBuffer, h, cl::sycl::read_only);
            cl::sycl::accessor accMatrix(matrixBuffer, h, cl::sycl::read_only);
            cl::sycl::accessor accOutput(outputBuffer, h, cl::sycl::write_only, cl::sycl::no_init);
                for (auto fbr { 0 }; fbr < fbrCnt; ++fbr) {
                    float tmp[colCnt];
                    #pragma unroll
                    for (auto col { 0 }; col < colCnt; ++col) {
                        tmp[col] = 0.0f;
                    for (auto ele { accFbrPtr[fbr] }; ele < accFbrPtr[fbr+1]; ++ele) {
                        const auto k { (accKIdx[ele] - 1) * colCnt };
                        const auto val { accValues[ele] };
                        #pragma unroll
                            tmp[col] += val * accMatrix[k + col];
                    #pragma unroll
                        accOutput[fbr * colCnt + col] = tmp[col];
    q.wait();
Filipe
BoonBengT_Intel
Hi @filipeborralho,
Noted on the details provided, the error seems to be coming from the RTL compilation complaining about some port.
Mind if I asked from which references design that you have gotten this code from?
And did the emulation and simulation compiled successfully?
Hope to hear from you soon.
Best Wishes
BB
filipeborralho
Hi @BoonBengT_Intel ,
This code is not from a reference design, it is my own. I was working on it before all this incident with the FPGAs and it was working fine.
I did try emulation and it worked but not simulation.
Filipe
BoonBengT_Intel
Hi @filipeborralho,
Apologies for the delayed, could you explain more on what are the incident mention with the FPGA?
And which nodes did you tried in the Devcloud for the build?
Would try our best to support this by emulation the design you have.
Best Wishes
BB
filipeborralho
For some reason it is now working, I don't really understand why it wasn't and now is but anyway it is working.
Thank you for your time.
Filipe
BoonBengT_Intel
Hi @filipeborralho,
Great! Good to know that it is working now, apologies for the inconvenient caused, it might be some platform glitch, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
