Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1712 Discussions
Read only filesystem Error with hello_afu getting started with AFU
Ruchit_rt
I am trying to get started with Intel DevCloud and am getting a read only filesysystem error when executing the following command from the hello_afu directory:-
afu_synth_setup --source hw/rtl/filelist.txt build_synth
Error is as follows:
OSError: [Errno 30] Read-only file system: 'build_synth'
directory structure can be seen here:-
 Please help me solve this.
Rahila_T_Intel
Good dat to you.
To assist you better, could you please let us know which DevCloud you are using? Is it DevCloud for Edge/oneAPI?
Ruchit_rt
Hi!
I am using Devcloud oneAPI I believe. I use ssh to get to devcloud. I also select Arria 10 PAC Compilation and Programming - RTL, AFU, OpenCL once I am sshed. I use version 1.2.1 of the Arria. After setting up the tools via tools_setup I do the above steps as shown in the previous post and face the readonly file error.
Thank you for you help - please let me know what to do.
Rahila_T_Intel
We are able to run the same from our end.
As you are trying to run the command from /glob , you are getting the "OSError: [Errno 30] Read-only file system: 'build_synth". Because it is not a writable space.
You can copy the hello_afu folder locally and do the same operation without any issues.
Please use the below commands.
1. Copy the folder :
cp -r /glob/development-tools/versions/fpgasupportstack/a10/1.2.1/inteldevstack/a10_gx_pac_ias_1_2_1_pv/hw/samples/hello_afu .
2. Move into that folder
cd hello_afu/
3. Run the command
Please find the screenshot for reference.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Rahila_T_Intel
We haven't heard back from you. Could you please provide an update?
Rahila_T_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
