Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1689 Discussions
Resource limit exceeded
ffa
I am getting this error after most of the command. Please help.
Also I am not able to check my storage using df -h
JaideepK_Intel
We can see from the screenshot that you are not providing an URL after the wget command. Please try to run most of the commands on the compute node.
To check the storage of the home directory, use the below command:
df -H .
or
du -sh <path to the directory>
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
df -H .
or
Jaideep
ffa
Hi Jaideep,
Using login node I am getting good internet speed. That's why I was using it.
JaideepK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
