I'm running some tests in Intel DevCloud portal with jupyter notebook, OpenVINO version 2021.1, when I run a job in the terminal connected to my notebook
qsub main_job.sh -l nodes=1:idc002mx8 -F "./models/intel/person-vehicle-bike-detection-crossroad-0078/FP16/person-vehicle-bike-detection-crossroad-0078.xml MYRIAD 0.75 ./video/in_video/test.mp4 ./video/out/out_test_cpui5_6500te_0078_8VPU.mp4 CPUi5_6500te_075_0078_8VPU.txt 50 2000 5 2000" -N TEST_CPUi5_6500te_075_0078_8VPU
the system works correctly, but once the operations have been performed in query device section log that I've in my code I can't see the MYRIAD device listed, and the code for the test on the MYRIAD VPUs doesn't execute well. This seems that the the job doesn't see the 8 VPU in the server machine. The strange thing is that when I execute the same job for 1 or 2 MYRIAD VPUs
qsub main_job.sh -l nodes=1:idc014upxa10fx1 -F "./models/intel/person-vehicle-bike-detection-crossroad-0078/FP16/person-vehicle-bike-detection-crossroad-0078.xml MYRIAD 0.75 ./video/in_video/test.mp4 ./video/out/out_test_cpui7_8665ue_0078_2VPU.mp4 CPUi7_8665ue_075_0078_2VPU.txt 50 2000 5 2000" -N TEST_CPUi7_8665UE_075_0078_2VPU
all the code performs well.
There are some reason why the job seem to doesn't seen the 8 MYRIAD VPUs on idc002mx8 compute node?
Hi junche4x,
Were you able to resolve your issue?
idc015ai5 does not have a VPU on node, hence the error.
We did test idc024 and did not run into any issues so it should be able to run HDDL.
Sahira
Thank you for posting in Intel Forums.
We are moving this case to Intel Devcloud for Edge Forum so that the subject matter experts can help you out.
Raeesa
There are two options. For using the myriad vpus, you can choose -d MYRIAD, or -d HDDL. If you choose MYRIAD then you must schedule inferences for each device, but if you choose HDDL, then the plugin will schedule the devices for you. Also have a look at examples for the MULTI plugin/device option for a simple round robin scheduler.
HDDL not works on some edge nodes. (idc015ai5/idc024...)
it says:
exec_net = ie.load_network(network=net, device_name=device)
File "ie_api.pyx", line 306, in openvino.inference_engine.ie_api.IECore.load_network
File "ie_api.pyx", line 315, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: no devices found
Hi junche4x,
Sahira
