Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1521 Discussions
Running batch FPGA compile jobs not working (qsub -l nodes=1:fpga_compile:ppn=2 -d . build.sh)
JVand22
I am trying to run FPGA compile jobs as batch jobs using the following command:
 where build.sh contains:
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
make hw -f Makefile.fpga.
The job always finishes in less than a second, with an empty error file (build.sh.eXXXX) and the following output file (build.sh.oXXXX):
# Date: Mon Feb 22 04:45:54 PST 2021
# Job ID: 799108.v-qsvr-1.aidevcloud
# User: u47378
# Resources: neednodes=1:fpga_compile:ppn=2,nodes=1:fpga_compile:ppn=2,walltime=06:00:00
:: WARNING: setvars.sh has already been run. Skipping re-execution.
To force a re-execution of setvars.sh, use the '--force' option.
Using '--force' can result in excessive use of your environment variables.
# End of output for job 799108.v-qsvr-1.aidevcloud
# Date: Mon Feb 22 04:45:59 PST 2021
I am able to run the build.sh script in an interactive session on an fpga_compile node with no problems, but as expected it takes a long time and it would be useful if I could queue multiple batch FPGA compile jobs.
What am I doing wrong?
Thanks!
AthiraM_Intel
Could you please include the path to the working directory (ie, the path to Makefile.fpga) in build.sh
build.sh contains:
#!/bin/bash
cd /<path>/
If the issue still persists, please let us know.
AthiraM_Intel
Could you please give us an update? Is your issue resolved?
JVand22
Yes - Adding 'cd <dir>' did the trick, the issue is now resolved.
Thanks!
AthiraM_Intel
Thanks for the confirmation. We would discontinue monitoring this issue, please raise a new thread if you have further issues.
