Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1638 Discussions
RuntimeError: Check 'PartialShape::merge_into(inputs_shape_scheme, this_input_shape)'
Karan
I had converted a .h5 file to a .onnx and then used the model optimizer to generate the .xml and .bin files. Everything worked just fine so far.
But when reading these files I get the above error. What is the reason for this error and how to fix it ?
ChithraJ_Intel
Hi Karan,
Thanks for reaching out to us!
We will be very happy to help you with your issue. Please let us know the environment in which you are trying out the workload. Is it in Devcloud or in your local machine. Also, please provide the complete steps you followed if possible. So that we will be able to investigate more on the issue you are facing.
Chithra
ChithraJ_Intel
Hi Karan,
Could please share the requested details with us, so we can help you more.
Chithra
ChithraJ_Intel
Hi Karan,
We have not heard back anything from you. So, we won't be monitoring this thread.If you need further assistance, please feel free to raise a new thread.
Chithra
