Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
SEP and PAX drivers for emon
ShankarRatneshwaran
I am trying to use emon to monitor data on my processes. When I run emon -v , I see that the sep and pax drivers are not installed properly. Can I please get some help
u138558@s001-n002:~$ emon -v
EMON Version .............. V11.30
Copyright(C) 1993-2020 Intel Corporation. All rights reserved.
Application Build Date: Nov 25 2021 at 08:58:16
SEP Driver Version: Error retrieving SEP driver version
PAX Driver Version: Error retrieving PAX driver version
Perf Kernel Version: 5.4.0-80-generic
Collection Mode: Driver
Device Type ............... Intel(R) Xeon(R) Processor code named Skylake
EMON Database ............. skylake_server
Platform type ............. 111
Error: No further information is available since drivers are not loaded.
Failed to communicate with sep driver. Please check if driver is properly loaded
Problem accessing the sampling driver. The driver may need to be (re)installed with appropriate group/file permissions
AthiraM_Intel
Thankyou for posting in Intel Communities.
Could you please let us know which DevCloud (oneAPI DevCloud/edge DevCloud/FPGA DevCloud) you are using?
ShankarRatneshwaran
AthiraM_Intel
Sorry for the inconvenience caused. There is a known issue with these drivers on CPU nodes and our team is working on that internally.
Our GPU nodes are installed with these drivers and are working fine.
You can get a GPU node from login node using the below command:
qsub -I -l nodes=1:gpu:ppn=2
Please find the below screenshot of the emon -V result in GPU node:
If this resolves your issue, please let us know.
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
