Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1689 Discussions
SSH DevCloud connection in Linux
TestDR
I used "Automated Configuration" to configure ssh connection.  Configuration went well. but I get error. Is it something to do with intel side or my local machine/proxy?
Rajitha
JaideepK_Intel
Thank you for posting in Intel communities.
The reason behind the error is that you are trying to access DevCloud via proxy
The workaround is to add proxy details to the proxycommand, as shown in the below screenshot.
After adding proxy details, please enter the below command to access DevCloud.
ssh devcloud.proxy
Note: If the issue still persists, please share your configuration file.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
