Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1352 Discussions
SSH connection Issue: " Connection timed out"
Saharsa
I am using Ubuntu, and I used ssh devcloud on my terminal but it throws an error:
ssh: connect to host devcloud.intel.com port 22: Connection timed out
kex_exchange_identification: Connection closed by remote host
I should point out, before I did not have any problem and I had an access to the devcloud, but this time no.
AlekhyaV_Intel
Hi Saharsa,
As your issue is resolved, Can we discontinue monitoring this thread?
Alekhya
MGRAV
Same here
AlekhyaV_Intel
Hi Saharsa,
Thank you for posting in Intel Forums. We apologize for the disruption caused.
We recently made small changes to the DNS entries for Intel DevCloud services. As a result, you may have had difficulty connecting to the DevCloud using SSH. In order to fix this issue, please replace all instances of devcloud.intel.com with ssh.devcloud.intel.com in your ~/.ssh/config file and let us know if it works.
Alekhya
Saharsa
Thank you for your response. The problem is when I try to access to the ssh.devcloud.intel.com, it through an error NET::ERR_CERT_AUTHORITY_INVALID,
Your connection is not private
Attackers might be trying to steal your information from ssh.devcloud.intel.com
and I can not do anything.
At the end, I deleted all my directory and started all again from the first point. and now it is work.
AlekhyaV_Intel
Hi Saharsa,
Alekhya
Saharsa
AlekhyaV_Intel
Thank you for accepting our solution. If you need any additional information, please submit a new thread as this thread will no longer be monitored.
Alekhya
