Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1522 Discussions
Scheduled into the void?
nsmeds
I tried to submit a test job that should execute on either of s017-n001 or s017-n002, but it is not running. What resources are available to me to evaluate on?
qsub -l nodes=1:dnp50:gpu:ppn=2 mybatch.job
Is there any commands beyond qnodes and qstat to see what nodes are defined and if nodes are on-line and can accept work?
Labels (2)
AlekhyaV_Intel
Thank you for posting in Intel Communities. Could you please let us know which DevCloud you're using? Is it DevCloud for oneAPI/Edge/FPGA?
And if you would like to check for a specific property in the nodes and get the node number, please use the below command:
pbsnodes | grep <property name> -A 6 -B 6
[Example: pbsnodes | grep gpu]
It's always better to confirm whether the nodes you're trying work on are free & working. Please use above commands before submitting a test job
Alekhya
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread would no longer be monitored by Intel.
Alekhya
nsmeds
Sorry,
Did not check in - need to set some kind of reminder so I get an email notice when there is a reply, I guess.
No, I can not say the issue has been resolved. However, the property I submitted for has vanished from the pbsnodes listing, so someone must have found something wrong in the declaration of available properties of the nodes I was aiming for?
/Nils
AlekhyaV_Intel
Hi @nsmeds ,
We have checked in oneAPI DevCloud for dnp50 property related nodes, s017-n001 & s017-n002 nodes, but we couldn't find any. Please let us know which DevCloud you're using so that we can debug your issue further.
Alekhya
AlekhyaV_Intel
Please give us an update regarding this issue.
Alekhya
AlekhyaV_Intel
We have not heard back from you. So we will close this thread now. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel
Alekhya
