Hello I have one error in the server today:
Last login: Wed Feb 5 18:36:36 2020 from 10.9.0.249
-bash: syntax error near unexpected token `Last'
u32408@login-2:~$ qstat
Job ID Name User Time Use S Queue
481144.v-qsvr-1 my_project_05 u32408 149:18:4 R batch
u32408@login-2:~$ qdel 481144.v-qsvr-1
qdel: Server could not connect to MOM 481144.v-qsvr-1.aidevcloud
We tried from our side and it works fine here.It might be a temporary issue.If the issue persists then try out
qstat -n
and share the screenshot of it and make sure no other jobs are running on it.
Hello
sharing the screenshot of my screen
u32408@login-2:~$ qstat -n
v-qsvr-1.aidevcloud:
Req'd Req'd Elap
Job ID Username Queue Jobname SessID NDS TSK Memory Time S Time
481144.v-qsvr-1.aidevc u32408 batch my_project_05 18196 1 2 120gb 24:00:00 R 32:08:14
s001-n011/0-1
Could you please check whether your job is still running because ideally it will be killed within 24 hours.If it is still running, then we will contact the admin team and let you know.
Good Morning
More than 24 hours have passed and the process is still seemingly active, but it allows you to roll other processes without difficulty. Could you inform me if this could generate a problem later in relation to the stopped process.
Here I send you a print of the screen using the qstat -n command.
Req'd Req'd Elap
481144.v-qsvr-1.aidevc u32408 batch my_project_05 18196 1 2 120gb 24:00:00 R 56:26:25
s001-n011/0-1
484261.v-qsvr-1.aidevc u32408 batch my_project_05 29476 1 2 120gb 24:00:00 R 00:00:38
s001-n055/0-1
Thanks for the help
Thanks for the update.We contacted the admin team and they have cleared your issue.Now you will be able to use qdel command.Kindly check it out and let us know.
Could you please let us know if your issue is resolved?
We are closing the case assuming that your issues got resolved.Feel free to open a new thread if you face any further issues.
