Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Slow speed
ffa
I am trying to download a dataset and it is showing 50+ minutes to download a 11gb dataset. I am using jupyter notebook in oneapi. The speed is less than 4Megabytes/s.
JaideepK_Intel
Good day to you.
Sorry to say this, but currently we can't increase interwork speed inside DevCloud, so could you please try to download your files with a good network into your local machine and upload them using scp or rsync?
examples:
scp -r SOURCE/ DESTINATION/
rsync -r SOURCE/ DESTINATION/
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
Good day to you.
Thank you for posting in Intel communities.
We are looking into this internally, One possible workaround is to download that dataset onto your local machine (if you have good network speed). With help of scp command try to upload the file into the devcloud.
example:
Open cygwin/mobax and run the below command:
scp -r <Path to the dataset> devcloud:<Path inside devcloud>
Jaideep
ffa
Hi Jaideep,
hope you’re doing well today! Unfortunately my network speed is less than that in DevCloud, so I cannot use my local machine.
JaideepK_Intel
Good day to you.
examples:
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
Good day to you.
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
