Hi. I am trying to finish the Intel Edge AI Developer certification but the jupyter notebooks won't spawn. My user id is u80606. Can I please get some help with this?
This issue should now be resolved, please let me know if you are still having issues.
Chris
Okay, so I found a workaround.
When your Jupyterhub window shows timeout, logout.
And then login from the same window. Click on home > My Server.
This will start an environment, Now you can go back to your dashboard and start your task.
@shubhambaid did not work for me, sadly. It's been over 12 hours and I'm still facing the same issue.
Thank you for the report, it is being investigated, I will update you as soon as I have more information.
Chris
Chris
