Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
Spawn failed: qsub: submit error (Job rejected by all possible destinations (check syntax, queue res
初慕苏流年
Spawn failed: qsub: submit error (Job rejected by all possible destinations (check syntax, queue resources, ...)) Always, help me
ChrisB_Intel
Can you clear your cache and cookies, log into Devcloud, and try and launch the server again? If it doesn't work please send me a screen shot of the behavior that you are seeing?
Chris
ChrisB_Intel
初慕苏流年,
I need a bit more information.
What Job were you running?
What block of code?
Do you have any screen shots of the error?
Are there any log files?
Any additional information you could provide would be appreciated.
Chris
初慕苏流年
The server can't start. I'm trying to restart multiple times
ChrisB_Intel
Chris
初慕苏流年
Spawn failed
The latest attempt to start your server has failed. Would you like to retry starting it?
Always, its link is:
https://notebooks.edge.devcloud.intel.com/hub/spawn-pending/u85072
But using this link is currently available:
https://notebooks.edge.devcloud.intel.com/user/u85072/tree?
After knowing the cache and cookies, it can be used at present, but the above results occasionally appear
ChrisB_Intel
I am glad it is currently working for you. We do have outages from time to time which is likely what is occurring when you are seeing that 500 error.
Please let me know if you have any questions.
Chris
