I attempted to install Spyder in my DevCloud ssh instance using
conda install spyder -c intel
and everything went well for a while then I started getting a bunch of errors like this one
InvalidArchiveError('Error with archive /home/u153568/.conda/pkgs/qt-5.9.7-h5867ecd_1rz9ygiga/info-qt-5.9.7-h5867ecd_1.tar.zst. You probably need to delete and re-download or re-create this file. Message from libarchive was:\n\nZstd decompression failed: Allocation error : not enough memory')
The installation failed.
Has anyone successfully installed Spyder on DevCloud recently?
Sunil
Good day to you.
To install a package in Intel DevCloud, we suggest you perform the following steps:
If using the pip installer,
pip install --user <package_name>
E.g.: pip install --user numpy
If using the conda installer,
conda create -y -n <environment_name>
conda activate <environment_name>
conda install <package_name>
E.g.:
conda create -y -n test_env
conda activate test_env
conda install numpy
From your query, we can understand that you are using Intel DevCloud connect via SSH to run Spyder. Unfortunately, GUI applications are not supported on Intel DevCloud for oneAPI. We recommend signing into your Intel DevCloud via a web browser and opening a Jupyter Lab session by visiting the below link to have an interactive GUI based interface:
https://jupyter.oneapi.devcloud.intel.com/hub/login?next=/lab/tree/Welcome.ipynb?reset
You can also open Jupyter Notebook by visiting the "Intel DevCloud - Get Started" page (https://devcloud.intel.com/oneapi/get_started/) and clicking on the "Launch Jupyter Lab" link under the section "Connect with Jupyter Lab" at the bottom of the page.
Alternatively, you can also use the Visual Studio Code to access Intel DevCloud as per the documentation in the link: https://devcloud.intel.com/oneapi/documentation/connect-with-vscode/
If this helps, do mark this as a solution as this will help others with a similar query.
Thanks and Regards,
Jyothis V James
Good day to you.
E.g.:
conda install numpy
Thanks and Regards,
Jyothis V James
Hi Jyothis,
Thanks - Will use VSCode as that is more intuitive to me.
Best Regards
Sunil
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jyothis V James
