Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1520 Discussions
TBB not found while linking
RKriemann
I'm trying to run a small program which uses oneMKL. While linking at the devcloud login system
I see the following error: "/usr/bin/ld: cannot find -ltbb". I also tried to compile in the PBS script before running the program but to no avail.
The program is compiled via "dpcpp -std=c++20 -mkl -o myprog myprog.cc".  Switching on verbose mode during compilation, I see that the TBB library directory is specified as needed for the linker.
Looking at the TBB directory
  /glob/development-tools/versions/oneapi/beta07/inteloneapi/tbb/latest/lib/intel64/gcc4.8/
I see libtbb.so.2. At my home installation of the same oneAPI I also have "libtbb.so" in the corresponding directory.
Is that some error during installation of oneAPI or do I have to add an additional parameter while linking ("-tbb" does not change anything).
RGDS
  Ronald
RahulV_intel
Looks like an MKL related issue. Redirecting this query to MKL/oneMKL forum.
Rahul
