Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
Tensorflow import error-Failed to map segment from shared object
AyushM
I'm getting an error when I try to run a python file which imports tensorflow.The conda env is already active.I'm following the steps from this link:https://devcloud.intel.com/oneapi/get_started/aiAnalyticsToolkitSamples/
This is the error:
(base) u61707@login-2:~/oneAPI-samples/AI-and-Analytics/Getting-Started-Samples/IntelTensorFlow_GettingStarted$ #!/bin/
bash
(base) u61707@login-2:~/oneAPI-samples/AI-and-Analytics/Getting-Started-Samples/IntelTensorFlow_GettingStarted$ source
/opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
activate tensorflow
(tensorflow) u61707@login-2:~/oneAPI-samples/AI-and-Analytics/Getting-Started-Samples/IntelTensorFlow_GettingStarted$ p
ython TensorFlow_HelloWorld.py
File "TensorFlow_HelloWorld.py", line 11, in <module>
import tensorflow.compat.v1 as tf
File "/glob/development-tools/versions/oneapi/gold/inteloneapi/intelpython/latest/envs/tensorflow/lib/python3.7/site-packages/tensorflow/__init__.py", line 41, in <mo
dule>
from tensorflow.python.tools import module_util as _module_util
File "/glob/development-tools/versions/oneapi/gold/inteloneapi/intelpython/latest/envs/tensorflow/lib/python3.7/site-packages/tensorflow/python/__init__.py", line 64,
in <module>
from tensorflow.python.framework.framework_lib import * # pylint: disable=redefined-builtin
File "/glob/development-tools/versions/oneapi/gold/inteloneapi/intelpython/latest/envs/tensorflow/lib/python3.7/site-packages/tensorflow/python/framework/framework_li
b.py", line 25, in <module>
from tensorflow.python.framework.ops import Graph
File "/glob/development-tools/versions/oneapi/gold/inteloneapi/intelpython/latest/envs/tensorflow/lib/python3.7/site-packages/tensorflow/python/framework/ops.py", lin
e 54, in <module>
from tensorflow.python.framework import dtypes
File "/glob/development-tools/versions/oneapi/gold/inteloneapi/intelpython/latest/envs/tensorflow/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py",
line 28, in <module>
from tensorflow.python import _pywrap_bfloat16
ImportError: /glob/development-tools/versions/oneapi/gold/inteloneapi/intelpython/latest/envs/tensorflow/lib/python3.7/site-packages/tensorflow/python/_pywrap_bfloat16.
so: failed to map segment from shared object
Please let me know how to resolve this.
RaeesaM_Intel
Hi Ayush,
Thank you for posting in Intel devcloud Forum.
The error is because you are in devcloud login node and trying to execute the commands in script file hello-world.sh separately. You have to be in compute node to be able to perform your tasks. You could reach an interactive compute node by using the below command, once you are connected to devcloud.
$qsub -I
-I (upper case i) is the argument used to request an interactive session.
Once you are in your compute node, the steps should work fine without any issues.
$cd ~/oneAPI-samples/AI-and-Analytics/Getting-Started-Samples/IntelTensorFlow_GettingStarted
$source /opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
$source activate tensorflow
$python TensorFlow_HelloWorld.py
Or follow the same steps as given in the tutorial link, by creating hello-world.sh file and then submitting it as a job. It should work fine in that case also and you will get output as :
Tensorflow HelloWorld Done!
[CODE_SAMPLE_COMPLETED_SUCCESFULLY]
To know more about login node and compute node , refer the following link : https://community.intel.com/t5/Intel-DevCloud/Login-Node-Versus-Compute-Node-in-Intel-DevCloud/m-p/1211227
Hope this helps.
Raeesa
RaeesaM_Intel
Hi Ayush,
Is your issue resolved ? Are you able to run the script without any errors ?Please let us know the updates.
Raeesa
RaeesaM_Intel
We haven't heard back from you. We are assuming that the solution provided helped and would no longer be monitoring this issue. Please raise a new thread if you have further issues.
Raeesa
