Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1472 Discussions
Terminal multiplexers (e.g, GNU screen, tmux)
User01
New Contributor II
I see that DevCloud login nodes don't provide GNU screen or tmux. I have a general habit of always starting a terminal multiplexer when I connect to systems with SSH so that if I lose the connection, or need to disconnect and reconnect from somewhere else, I don't lose work. I realize that persistent screen or tmux sessions can use systems resources, but in practice they seem to be a good balance of improving user experience without being resource hogs. Does DevCloud provide any terminal persistence solutions to reduce the risk of lost work due to disconnects?
AbhijeetJ_Intel
You can use DevCloud JupyterLab for tmux features in compute nodes.
https://jupyter.oneapi.devcloud.intel.com/
JupyterLab nodes can help you to reduce the risk of lost work due to disconnects.
Abhijeet
AbhijeetJ_Intel
Abhijeet
User01
New Contributor II
That is an interesting alternative technique. I'd have to change my work habits quite a bit to shift from GNU screen / tmux to JupypterLab. Thanks for the response.
AbhijeetJ_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Abhijeet
