Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1645 Discussions
The compilation problem of calling FPGA and GPU in file
HYB
Use the FPGA queue in the main file test.cpp and call the function in gpu.cpp. The function uses the GPU queue. How to compile the file, the following compilation statement has an error: terminate called after throwing an instance of 'CL:: sycl:: runtime_ error'
Compile command:
dpcpp -DFPGA_EMULATOR \-fsycl-targets=spir64_fpga-unknown-unknown-sycldevice gpu.cpp \-c -o gpu.o
dpcpp -DFPGA_EMULATOR \-fsycl-targets=spir64_fpga-unknown-unknown-sycldevice,spir64-unknown-unknown-sycldevice test.cpp gpu.o -o test test.cpp gpu.hpp gpu.cpp
test.cpp
gpu.hpp
gpu.cpp
AthiraM_Intel
Could you please follow the below steps:
1. Replace your build.sh file by the below commands:
dpcpp -DFPGA_EMULATOR gpu.cpp \-c -o gpu.o
dpcpp -DFPGA_EMULATOR test.cpp gpu.o -o test
2. Run build.sh and run.sh files:
qsub -l nodes=1:gpu:ppn=2 -d . build.sh
qsub -l nodes=1:gpu:ppn=2 -d . run.sh
Please find the attached result (Image.PNG) for reference.
Hope this helps. If you have any further issue, please let us know.
AthiraM_Intel
Could you please share sample reproducer code and the complete steps, so that we can try out the same from our end?
HYB
test.cpp
#include <stdio.h>
#include <stdlib.h>
#include "gpu.hpp"
#include <CL/sycl.hpp>
#include <CL/sycl/INTEL/fpga_extensions.hpp>
using namespace std;
using namespace cl::sycl;
int main(){
queue Q{ INTEL::fpga_emulator_selector{} };
std::cout << "Running on device: " << Q.get_device().get_info<info::device::name>() << "\n";
int size = 16;
int *data = (int *)malloc(sizeof(int)*size);
int *device_data = malloc_device<int>(size,Q);
for (int i = 0; i < size; i++) {
data[i] = i; printf("%d\t",data[i]);
} printf("\n");
Q.memcpy(device_data, data, sizeof(int) * size);
Q.submit([&](auto &h) {
h.parallel_for(range{ size_t(size) }, [=](id<1> i) {
device_data[i] = device_data[i] * 10;
Q.memcpy(data, device_data, sizeof(int) * size);
printf("the data on fpga is:\n");
} printf("\n");
addOnGpu();
free(data);
free(device_data,Q);
return 0;
gpu.hpp
#include <stdio.h>
#include <stdlib.h>
void addOnGpu();
gpu.cpp
#include "gpu.hpp"
void addOnGpu(){
queue Q{ cl::sycl::gpu_selector{} };
//queue q{ INTEL::fpga_emulator_selector{} };
std::cout << "Running on GPU device: " << Q.get_device().get_info<info::device::name>() << "\n";
int size = 16;
} printf("\n");
device_data[i] = device_data[i] * 100;
} printf("\n");
//addOnGpu(data,size);
free(data);
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
HYB
test.cpp
#include <stdio.h>
#include <stdlib.h>
#include "gpu.hpp"
int main(){
int size = 16;
} printf("\n");
} printf("\n");
addOnGpu();
free(data);
return 0;
gpu.hpp
#include <stdio.h>
#include <stdlib.h>
void addOnGpu();
gpu.cpp
#include "gpu.hpp"
void addOnGpu(){
int size = 16;
} printf("\n");
} printf("\n");
free(data);
build.sh
run.sh
./test
The control command at the control panel end is:
qsub -l neednodes=1:fpga_compile:ppn=2,nodes=1:fpga_compile:ppn=2 -d . build.sh
qsub -l neednodes=1:fpga_compile:ppn=2,nodes=1:fpga_compile:ppn=2 -d . run.sh
Can't output correct results, what's the problem?
AthiraM_Intel
Could you share the error log and respective screenshot?
Also we are facing error while trying your command. So try the below commands.
qsub -l nodes=1:fpga_compile:ppn=2 -d . build.sh
qsub -l nodes=1:fpga_compile:ppn=2 -d . run.sh
If the issue still persists, please let us know.
HYB
There was still an error trying your command.
AthiraM_Intel
HYB
Thank you very much for your guidance. I finished the task successfully
HYB
AthiraM_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
