Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1137 Discussions
The compilation problem of calling FPGA and GPU in file
HYB
Use the FPGA queue in the main file test.cpp and call the function in gpu.cpp. The function uses the GPU queue. How to compile the file, the following compilation statement has an error: terminate called after throwing an instance of 'CL:: sycl:: runtime_ error'
Compile command:
dpcpp -DFPGA_EMULATOR \-fsycl-targets=spir64_fpga-unknown-unknown-sycldevice gpu.cpp \-c -o gpu.o
dpcpp -DFPGA_EMULATOR \-fsycl-targets=spir64_fpga-unknown-unknown-sycldevice,spir64-unknown-unknown-sycldevice test.cpp gpu.o -o test
test.cpp
gpu.hpp
gpu.cpp
JananiC_Intel
Thanks for posting in Intel forums.
Since this is a duplicate thread of https://community.intel.com/t5/Intel-DevCloud/The-compilation-problem-of-calling-FPGA-and-GPU-in-fil..., we will no longer monitor this thread.We will continue addressing this issue in the other thread.
Janani Chandran
