Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1689 Discussions
The user names I see in jupyterhub and connect with cygwin are different.
Luoxue
Hello, the user names I see in jupyterhub and connect with cygwin are different. The user name I see in jupyterhub is u85553, and the user name I see in connect with cygwin is u5555. Can you help me?
ChrisB_Intel
Luoxue,
I think you might be connecting into 2 different DevClouds. We have several different DevClouds up and running and it is very easy to confuse them,.
I believe the 2 your are mixing up are:
Devcloud.intel.com/Edge
Devcloud.intel.com/Oneapi
We don't currently support connecting via Cygwin on Devcloud.intel.com/Edge, only on Devcloud.intel.com/Oneapi. Which is likely why you are seeing two different things via the two interfaces. Additionally, the username starting with U8 is an Edge username, I believe the U5, is a OneAPI username.
Hope that helps, please let me know if you have any additional questions.
Chris
ChrisB_Intel
Luoxue,
Chris
