- Email to a Friend
Some useful packages is not installed on devcloud, but you can easy install it locally for convenient work.
Lets install for example 7zip by hand :
1) First of all you have to set some paths in ~/.bash_profile
# ===================================================== var_add_path(){ # Use var_add_path "VAR" "/path/to/smth" "s|e" # s - at the beginning; e - at the end # echo "Adding $2 to $1 at the <start|end> $3" tmp_var=$1 if [ -d "$2" ]; then if [[ ":${!tmp_var}:" != *":$2:"* ]]; then # For non-empty, only add if not already there if [[ "$3" == "s" ]]; then [[ -z "${!tmp_var}" ]] && export $1=$2 || export $1=$2:${!tmp_var} else [[ -z "${!tmp_var}" ]] && export $1=$2 || export $1=${!tmp_var}:$2 fi fi fi } # ===================================================== var_add_path "PATH" "$HOME/.local/bin" "s" var_add_path "PATH" "$HOME/bin" "s" var_add_path "PATH" "/bin" "e" var_add_path "LD_LIBRARY_PATH" "$HOME/.local/lib" "e"
2) Get, unpack, change and install p7zip-full
mkdir ~/src cd ~/src apt download p7zip-full dpkg -x p7zip-full_16.02+dfsg-6_amd64.deb p7zip cd p7zip/usr/bin sed -i 's,\/usr,$HOME\/.local,' 7za sed -i 's,\/usr,$HOME\/.local,' 7z mv * ~/bin/ cd .. mv lib/* ~/.local/lib/ mv share/* ~/.local/share/
Now you can use 7z as usual.
Also you can install Midnight Commander and other packages by the same way. If it asks for some libs - place them to ~/.local/lib/
For MC you have to set in ~/.bashrc
MC_DATADIR=$HOME/.local/share/mc
To see how their MC searches for components, use the mc -F command
- Tags:
- Community
- Email to a Friend
Thanks for the information provided. It will definitely help many forum users :)
Topic Options
