Do you know why after using devcloud for a moment everyday then you cannot compile/run anything anymore and not just my code but all the codes of the training modules for oneAPI base toolkit have this kind of output as well when you compile/run: "
TimeOut 60 seconds: Job is still queued for execution, check for output file later (run_buffer_destruction.sh.o1015610)
Hello amadou,
To better assist you, we have moved your question to another forum.
Adrian M.
We are able to run the Basetool kit samples. Please follow the below steps for vector-add sample.
Connect to the Devcloud:
ssh devcloud
Currently you are in login node then connect to compute node :
qsub -I
Download the samples.
git clone https://github.com/oneapi-src/oneAPI-samples.git
Go to the vector-add sample
cd oneAPI-samples/DirectProgramming/DPC++/DenseLinearAlgebra/vector-add/
Build and run the sample in batch mode
Create the job scripts
vi build.sh
Paste the following contents in build.sh script
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
make clean
make all
Create a run.sh script
vi run.sh
Paste the following contents in run.sh script
#!/bin/bash
make run
Build the sample on a gpu node.
qsub -l nodes=1:gpu:ppn=2 -d . build.sh
To inspect the job progress
watch -n 1 qstat -n -1
Run the sample on a gpu node after the build job completes successfully.
qsub -l nodes=1:gpu:ppn=2 -d . run.sh
After running the above command the out put is going to save in file (eg: run.sh.o1018851)
Note:
How to change job timeout (max = 24h)
By default, any jobs will be terminated automatically at the 6h mark. Use the following syntax if your job requires more than 6h to complete.
qsub -I -l walltime=hh:mm:ss
eg: qsub -I -l walltime=10:00:00
Please share your Devcloud id if you are facing same issue after running the above steps.
Jaideep
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
I assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
I also have this problem when using jupyter notebook.
I try following the solution described above but I got stuck at ssh. I waited and there is no response.
oop! user error. I can ssh now. Please ignore my previous comment.
