Hi today September 22,2022 4:00 PM Local Time (GMT+7)
I tried to connect to devcloud using SSH using MobaXterm but the connection attempt is unsuccessful/Timeout. Last night I still able to connect to devcloud. Is there maintenance going on /server down/ssh configuration change?
Daniel
Issue is resolved now. Please try to connect to DevCloud and let us know.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Please let us know if we can close this case.
Shyam Sundar
Could you please provide any update?
Shyam Sundar
I assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shyam Sundar
