Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
Trouble selecting GPU node on DevCloud
rudkin__Illya
Hi, I have created a very simple DPC++ program. If I use the default device selection; sycl::queue myQueue( ); I get given the intel FPGA and code works fine. However if I try sycl::queue myQueue( sycl::gpu_selector{} ); with the command ./q run.sh where q = qsub script with qsub -l nodes=1:gpu:ppn=2 -d . I get the following:
u40402@s001-n049:~/cppVecAdd$ ./q run.sh
Submitting job:
589866.v-qsvr-1.aidevcloud
Job ID                    Name             User            Time Use S Queue
589795.v-qsvr-1            ...ub-singleuser u40402          00:00:44 R jupyterhub
589866.v-qsvr-1            run.sh           u40402                 0 Q batch
Waiting for Output.......
#      Date:           Tue May  5 00:07:23 PDT 2020
#    Job ID:           589866.v-qsvr-1.aidevcloud
#      User:           u40402
# Resources:           neednodes=1:gpu:ppn=2,nodes=1:gpu:ppn=2,walltime=06:00:00
:: setvars has already been run. Skipping any further invocation.  To force its re-execution, pass --force
########## Executing the run
########## Done with the run
# End of output for job 589866.v-qsvr-1.aidevcloud
# Date: Tue May  5 00:07:27 PDT 2020
terminate called after throwing an instance of 'cl::sycl::runtime_error'
  what():  No device of requested type available. Please check https://software.intel.com/en-us/articles/intel-oneapi-dpcpp-compiler-system-requirements-beta -1 (CL_DEVICE_NOT_FOUND)
/var/spool/torque/mom_priv/jobs/589866.v-qsvr-1.aidevcloud.SC: line 5: 13969 Aborted                 ./bin/cppVecAdd
How do I choose a GPU device instead of a FPGA device? Thanks
AthiraM_Intel
Please be informed that, s001-n049 is not a node with GPU.
 You can request the node with GPU on the DevCloud using the below command.
qsub -I -l nodes=1:gpu:ppn=2 -d .
Please try this and let us know if you have any further issues.
rudkin__Illya
Hi
Thank you. Ok I re-run my executable with the extra -I parameter:
and in the code used
and then with
          sycl::queue myQueue; // default = FPGA
both times run the executable with
            ./q run.sh
Both timed out after 40secs
If I do not use the q script (which now uses ‘qsub -I -l nodes=1:gpu:ppn=2 -d . $script’)  the SYCL code works but on FPGA.
The extra parameter has not worked here.
Anything thing else to try?
rudkin__Illya
I also tried the following. I typed the following on the command line
                qsub -I -l nodes=1:gpu:ppn=2 -d . run.sh
the terminal responsed with
                qsub: waiting for job 590100.v-qsvr-1.aidevcloud to start
and does not complete, it appears to hang
Again checking without using qsub just  ./run.sh the program runs outputting text to the command line.
rudkin__Illya
Hi, I am assuming this is a bug with DevCloud. Intel support has gone quiet. Trying to get instructions on 'qsub'. Man qsub does not work. Any information on how to use qsub?
rudkin__Illya
I tried again, went into the q script and edited the line qsub replacing -1/l with -l (L). Retyped nodes=1:gpu:ppn=2 -d . $script.
It worked!?! Not quite understanding if I changed anything.
#      Date:           Thu May  7 05:07:25 PDT 2020
#    Job ID:           591911.v-qsvr-1.aidevcloud
#      User:           u40403
Device name         : Intel(R) Gen9 HD Graphics NEO
Vendor name         : Intel(R) Corporation
Driver version      : 20.12.16259
Address bits        : 64
Max work-group size : 256
AthiraM_Intel
Glad to know that your issue got resolved.
This command is used to request the node with GPU on the DevCloud
qsub -l nodes=1:gpu:ppn=2 -d . run.sh
This command is used for running shell script in GPU node from login node.
Sometimes  the login  may show waiting due to unavailability of GPU nodes. Try  after sometime resolves this issue.
Since your issue got resolved, can we close this thread?
rudkin__Illya
Ok, after some more usage on off through out yesterday this is still problematic. I still more often than not get timeouts using the same qsub command and parameters you have given. It is not 100%, it is a gamble. Is there a way to guarantee get this to work every time?
AthiraM_Intel
Kindly check if any node with GPU is free(using pbsnodes command), when the qsub command fails.
The list of the nodes with GPU can be obtained by the below command:
pbsnodes | grep -B4 "gen9"
You can request a specific node which is free using the below command
qsub -I -l nodes=s001-nxxx:gpu:ppn=2 -d .
Note: Please change nxxx to available free node number
For example:
qsub -I -l nodes=s001-n233:gpu:ppn=2 -d .
Hope this helps.
AthiraM_Intel
We are closing this case assuming the solution provided was helpful. Please feel free to open a new thread in case of further queries.
