Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1642 Discussions
Unable to connect with x2go nodes - for GUI access
mahinlma
qsub: submit error (Unauthorized Request  MSG=group ACL is not satisfied: user uxxxxx@login-2, queue batch)
Please let me know, how to fix this issue.
Also let me know, is there any other way to access devcloud GUI for accessing Intel Quartus tools
Mahi
JananiC_Intel
Thanks for reaching out.
1)Could you give us the command and steps used for submitting the job?
2)Regarding devcloud GUI ,if you are using FPGA devcloud kindly post you questions in
https://forums.intel.com/s/topic/0TO0P0000001AUUWA2/intel-high-level-design?language=en_US
If you are in datacenter devcloud then you can try X11 forwarding which  is a mechanism that allows a user to start up remote applications but forward the application display to your local Windows machine.To enable X11 forwarding from your compute node to your windows server ,please follow the below steps
1)ssh to devcloud with -X flag (will in turn forward this display to your window server)
eg:
ssh -X devcloud
2)When requesting compute node use the -X flag(will forward the display  to compute node)
eg:
qsub -X  -I
Note: #2 will forward the display  to compute node and #1 will in turn forward this display to your window server
JananiC_Intel
Has this issue been resolved?Could you give us an update?
JananiC_Intel
We are closing the case assuming that your issues got resolved.Feel free to open a new thread if you face any further issues.
