Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1270 Discussions
Unable to log into dev cloud account with my personal computer
Aji
I am unable to log into my intel dev cloud account when using my personal computer. However, I have no issues logging into it with my intel provided computer. I have tried setting up my device to get access through Intel Azure Portal authentication but to no success. What steps can I take to login using my personal computer?
Aji
JesusE_Intel
Hi Aji,
Thank you for providing the additional information. I am able to launch my Jupyter Notebook on my personal computer using my Intel Credentials. I looked at your account and everything seems to be in order. Are you able to launch Jupyter Notebook on your work computer? Could you try using an Incognito browser on your personal computer? If you still run into the same issue, please try and see if your able to access Intel Developer Cloud for the Edge using the following link.
https://notebooks.edge.devcloud.intel.com/hub/login?next=/lab&RefURL=/content/www/us/en/developer/to...
Jesus
VaradJ_Intel
Hi ,
Thank you for posting in Intel communities.
Please can you answer the following questions:
1. Which DevCloud are you using? Is it Intel DevCloud for oneAPI or Intel DevCloud for the Edge or Intel DevCloud for FPGA ?
2. Which process you are trying to access Devcloud? Is it via cygwin or Jupyterlab?
3. Also, can you please share the detailed steps which you are following and the screenshot the error?
Thank You!
Varad
Aji
1. I'm using the  Intel DevCloud for the Edge for Intel Edge AI Certification course.
2. I'm trying to use the DevCloud via JupyterLab
3. I tried to access the jupyter lab through the Intel Edge AI Certification course. Intel Learning The screenshot below depicts how I am able to access the jupyter labs using the intel provided computer which works fine clicking on the link(see blue arrow on screenshot).
On my personal computer:
- I get the following error trying to access the Intel Edge AI Certification course using intel credentials:
"The requested URL was rejected. Please consult with your administrator
 Your support ID is: 6883575551462384628"
* I get the following error when accessing the intel devCloud using my intel credentials which also ask me to authenticate through the Intel Azure Portal
 Your support ID is: 6883575551462440036"
PS: i'm using the EmployeeHotspot wifi on my personal computer
Aji
JesusE_Intel
Hi Aji,
Jesus
Aji
Thank you! Your suggestion to try incognito mode worked.
JesusE_Intel
