Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
Unable to run power analysis on DevCloud
mnt
Hi
I have connected to the web interface of vtune on DevCloud. According to the manual here, I sould see a check box for "Analyze power usage" in the HotSpot section. However, I don't see that.
The node that I have connected is n068 which has Xeon(R) Gold 6128 CPU that is Skylake. I guess the architecture doesn't support power analysis. Am I right? Then is there a node that I can run power analysis? How?
RemyaP_Intel
Thank you for posting in Intel communities.
Sorry to say, but this feature is not currently not supported in DevCloud.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Remya Premdas
RemyaP_Intel
Remya Premdas
RemyaP_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
