Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1470 Discussions
Unable to schedule jobs using qsub.
PrasannaIITM
I am not able to run my scripts using qsub. Whenever I schedule my jobs in build.sh using qsub, it is removed from the queue within one second. I was able to run it till today morning.
command used to schedule jobs:
qsub -l nodes=1:gpu:ppn=2 -d . build.sh
I tried to do it without requesting GPU too. It gets removed from the queue immediately.
PrasannaIITM
The build.sh.exx generate file is also empty. The build.sh.oxx file has the following contents:
# Date: Tue 04 Oct 2022 02:21:46 AM PDT
# Job ID: 2002983.v-qsvr-1.aidevcloud
# User: u171677
# Resources: neednodes=1:gpu:ppn=2,nodes=1:gpu:ppn=2,walltime=06:00:00
# End of output for job 2002983.v-qsvr-1.aidevcloud
# Date: Tue 04 Oct 2022 02:21:47 AM PDT
JaideepK_Intel
In order to understand your issue (Account specific or build.sh script specific), can you try to run the below sample?
  • Create a file named "fibonacci.py" in your home directory.
example:
vi fibonacci.py (copy below content in side fibonacci.py)
def Fibonacci(n):
  # Check if input is 0 then it will
  # print incorrect input
  if n < 0:
    print("Incorrect input")
  # Check if n is 0
  # then it will return 0
  elif n == 0:
    return 0
  # Check if n is 1,2
  # it will return 1
  elif n == 1 or n == 2:
    return 1
  else:
    return Fibonacci(n-1) + Fibonacci(n-2)
# Driver Program
print(Fibonacci(43))
  • Create a file named "job.sh" in your home directory.
  • Inside job.sh copy the below content
#!/bin/bash
echo "start"
echo $(python3 ~/fibonacci.py)
echo "end"
qsub -l nodes=1:gpu:ppn=2 -d . job.sh
After running the above command, 2 files are going to be generated that look like job.sh.exx which is empty and job. sh.o.xx is going to have some content which looks like below.
Jaideep
JaideepK_Intel
good day to you.
Can you please try the above steps and give us an update?
Jaideep
PrasannaIITM
Sorry for the late reply, the issue is resolved now.
JaideepK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
