I'm having some difficulty selecting a GPU node on DevCloud. When I run this command to request a GPU node:
qsub -I -l nodes=1:gpu:ppn=2,walltime=01:00:00
I find that the node I am allocated doesn't actually have a GPU device, despite pbsnodes claiming that it does e.g. for the s001-n166 node:
pbsnodes | grep -A6 "^s001-n166"
s001-n166
state = job-exclusive
power_state = Running
np = 2
properties = xeon,cfl,e-2176g,ram64gb,net1gbe,gpu,gen9
ntype = cluster
jobs = 0-1/1926896.v-qsvr-1.aidevcloud
The output from clinfo does not show a GPU:
clinfo | grep " Device Name "
Device Name Intel(R) FPGA Emulation Device
Device Name Intel(R) Xeon(R) E-2176G CPU @ 3.70GHz
I cannot see a GPU device from within SYCL when running on a device with the gpu property - see this example code:
#include <CL/sycl.hpp>
#include <iostream>
int main() {
for (auto &device : sycl::device::get_devices()) {
std::cout << device.get_info<sycl::info::device::name>() << std::endl;
Output when executing this on s001-n167:
SYCL host device
Is there an issue with the qsub properties at the moment, or am I doing something wrong?
Adam
Hi Adam,
Thank you for posting in Intel Communities. We would like to know which DevCloud you're using. Are you using DevCloud for oneAPI/FPGA/Edge?
We tried to access GPU nodes, i.e. s001-166 & s001-167 on DevCloud for oneAPI and we could see that the graphics card is present. We have attached the screenshots below.
Please try once again with the below commands to access the above mentioned nodes & see if the issue stills persists. If yes, please provide error screenshots to us so that we can debug your issue further.
To access a specific node:
qsub -I -l nodes=s001-166:ppn=2 -d .
qsub -I -l nodes=s001-167:ppn=2 -d .
Run the command which you provided:
Alekhya
Hi Adam,
Alekhya
Thanks for your reply! I have no idea what has changed since yesterday but I can now see the GPUs when I request a GPU node.
Glad to know that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
