Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1718 Discussions
Unable to submit the job to execute the CNN algorithm on both core and gpu
Suhaas12
/var/spool/torque/mom_priv/jobs/2320709.v-qsvr-1.aidevcloud.SC: line 11: import: command not found
from: can't read /var/mail/tensorflow.keras.datasets
/var/spool/torque/mom_priv/jobs/2320709.v-qsvr-1.aidevcloud.SC: line 23: import: command not found
/var/spool/torque/mom_priv/jobs/2320709.v-qsvr-1.aidevcloud.SC: line 24: import: command not found
/var/spool/torque/mom_priv/jobs/2320709.v-qsvr-1.aidevcloud.SC: line 26: import: command not found
/var/spool/torque/mom_priv/jobs/2320709.v-qsvr-1.aidevcloud.SC: line 32: syntax error near unexpected token `,'
/var/spool/torque/mom_priv/jobs/2320709.v-qsvr-1.aidevcloud.SC: line 32: `(x_train, y_train), (x_test, y_test) = cifar10.load_data()'
I am getting the above error file when i tried to submit the job using the command
qsub -l nodes=1:core:ppn=2 -d . CIFAR10.py
I have attached the script file which i tried to run as a job.
Can I get any help regarding this, Is the format correct to submit the job.
RemyaP_Intel
Thank you for posting in Intel communities.
You can try submitting the job in batch mode. Here is the documentation for the same.
You may also, follow the below steps:
1. Create a job.sh with the below commands.
source /glob/development-tools/versions/oneapi/2022.3.1/inteloneapi/setvars.sh --force
conda activate <env_name>
python <python_program>.py
If you are facing any issues in activating the command, try:
source activate <env_name>
2. And create a .py file for your Python program
3. Once these two are created, you can run the job using the command :
uxxxxxx@login-2:~$ qsub -l nodes=1:core:ppn=2 -d . job.sh
2322656.v-qsvr-1.aidevcloud
It may take some time (depending on your code) to complete the job.
You can watch the status of the job using the command: watch qstat
When the job completes, give the ls command. You would be able to see two files job.sh.oxxxxxxx and job.sh.exxxxxxx representing the output and error files. You can check them to see the output and errors/warnings.
Let us know if you face any issues in following these steps.
Otherwise, if this resolves your issue, please make sure to accept this as a solution. This would help others with similar issues. Thank you!
Remya Premdas
RemyaP_Intel
Remya Premdas
RemyaP_Intel
We haven't received any response from your end. Is your issue resolved?
Remya Premdas
RemyaP_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
