Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
Unable to use pip command in DevCloud for me as a user
Soubhik_Das
Innovator
Following is the error for installing python packages in DevCloud terminal using pip.
Traceback (most recent call last):
  File "/glob/intel-python/python3/bin/pip", line 6, in <module>
    sys.exit(pip.main())
AttributeError: module 'pip' has no attribute 'main'
Ha__Phillip
Yes, I got the same error report when using pip to install any package to --user space.  We need help from admin to reinstall pip.
Phillip
ChithraJ_Intel
Could you please let us know the installation steps that you have followed and where you are trying out.
Kindly attach the screenshots of the installation, so that we can try it from our end.
ChithraJ_Intel
    Could you please provide the requested details.
    Meanwhile,try to install the package after creating a conda environment using below commands.
    conda create -n my_env python=3.6
    conda activate my_env
    pip install <package_name> --user
<package_name> - package that you are trying to install
Soubhik_Das
Innovator
u31658@s001-n052:~$     conda create -n my_env python=3.6
WARNING: The conda.compat module is deprecated and will be removed in a future release.
Collecting package metadata: done
Solving environment: done
==> WARNING: A newer version of conda exists. <==
  current version: 4.6.11
  latest version: 4.8.0rc0
Please update conda by running
    $ conda update -n base -c defaults conda
## Package Plan ##
  environment location: /home/u31658/.conda/envs/my_env
  added / updated specs:
    - python=3.6
The following packages will be downloaded:
    package                    |            build
    bzip2-1.0.6                |               19         100 KB  file:///opt/intel/inteloneapi/conda_channel
    certifi-2018.1.18          |           py36_2         143 KB  intel
    intelpython-2021.1b3       |                3           4 KB  file:///opt/intel/inteloneapi/conda_channel
    libgcc-ng-9.1.0            |       hdf63c60_0         8.1 MB  file:///opt/intel/inteloneapi/conda_channel
    openssl-1.0.2s             |                0         2.2 MB  intel
    pip-19.1.1                 |           py36_0         1.9 MB  intel
    python-3.6.9               |                5        24.6 MB  intel
    setuptools-41.0.1          |           py36_0         611 KB  intel
    sqlite-3.28.0              |                0         2.3 MB  intel
    tcl-8.6.4                  |               24         1.3 MB  file:///opt/intel/inteloneapi/conda_channel
    tk-8.6.4                   |               29         1.1 MB  file:///opt/intel/inteloneapi/conda_channel
    xz-5.2.4                   |       h14c3975_7         417 KB  file:///opt/intel/inteloneapi/conda_channel
    zlib-1.2.11                |       h14c3975_7         118 KB  file:///opt/intel/inteloneapi/conda_channel
                                           Total:        42.8 MB
The following NEW packages will be INSTALLED:
  bzip2              conda_channel/linux-64::bzip2-1.0.6-19
  certifi            intel/linux-64::certifi-2018.1.18-py36_2
  intelpython        conda_channel/linux-64::intelpython-2021.1b3-3
  libgcc-ng          conda_channel/linux-64::libgcc-ng-9.1.0-hdf63c60_0
  openssl            intel/linux-64::openssl-1.0.2s-0
  pip                intel/linux-64::pip-19.1.1-py36_0
  python             intel/linux-64::python-3.6.9-5
  setuptools         intel/linux-64::setuptools-41.0.1-py36_0
  sqlite             intel/linux-64::sqlite-3.28.0-0
  tcl                conda_channel/linux-64::tcl-8.6.4-24
  tk                 conda_channel/linux-64::tk-8.6.4-29
  wheel              intel/linux-64::wheel-0.31.0-py36_3
  xz                 conda_channel/linux-64::xz-5.2.4-h14c3975_7
  zlib               conda_channel/linux-64::zlib-1.2.11-h14c3975_7
Proceed (/n)?
Downloading and Extracting Packages
tk-8.6.4             | 1.1 MB    | ################################################################################ | 100%
zlib-1.2.11          | 118 KB    | ################################################################################ | 100%
setuptools-41.0.1    | 611 KB    | ################################################################################ | 100%
openssl-1.0.2s       | 2.2 MB    | ################################################################################ | 100%
libgcc-ng-9.1.0      | 8.1 MB    | ################################################################################ | 100%
tcl-8.6.4            | 1.3 MB    | ################################################################################ | 100%
intelpython-2021.1b3 | 4 KB      | ################################################################################ | 100%
xz-5.2.4             | 417 KB    | ################################################################################ | 100%
python-3.6.9         | 24.6 MB   | ################################################################################ | 100%
sqlite-3.28.0        | 2.3 MB    | ################################################################################ | 100%
pip-19.1.1           | 1.9 MB    | ################################################################################ | 100%
certifi-2018.1.18    | 143 KB    | ################################################################################ | 100%
bzip2-1.0.6          | 100 KB    | ################################################################################ | 100%
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
#     $ conda activate my_env
# To deactivate an active environment, use
#     $ conda deactivate
u31658@s001-n052:~$     conda activate my_env
CommandNotFoundError: Your shell has not been properly configured to use 'conda activate'.
To initialize your shell, run
    $ conda init <SHELL_NAME>
Currently supported shells are:
  - bash
  - fish
  - tcsh
  - xonsh
  - zsh
  - powershell
See 'conda init --help' for more information and options.
IMPORTANT: You may need to close and restart your shell after running 'conda init'.
u31658@s001-n052:~$ pip install opencv-python --user
  - bash
  - fish
  - tcsh
  - xonsh
  - zsh
  - powershell
u31658@s001-n052:~$ pip install numpy
u31658@s001-n052:~$ ^C
u31658@s001-n052:~$
The issue is still not resolved.
Soubhik_Das
Innovator
Can this issue be resolved soon as I have to submit project code?
ChithraJ_Intel
    We are also able to re-produce your issue(refer the screenshot1). Actually, this issue exists only with new Devcloud accounts.
    If you want to install the package in base environment( /glob/intel-python/python3/bin/python), you can try with following command which worked for us.(refer the screenshot2)
    pip3 install <package-name> --user
    Otherwise, if you are planning to use the conda environment that you have created already, then activate the environment with below command and try the installation.
    source activate my_env
Soubhik_Das
Innovator
The issue is resolved now. I'm able to install pip packages locally. Thanks
ChithraJ_Intel
Thank you for the confirmation. We are closing the thread. Please feel free to raise a new thread for further issues.
