Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1661 Discussions
Unknown dataset type: DL Workbench - Importing validation dataset
pramosg
@ChrisB_Intel
I am pretty new using the DL workbench. I would like to test some models our team has created (Semantic Segmentation models). I also have the validation data structure as you mention in the documentation https://docs.openvinotoolkit.org/latest/workbench_docs_Workbench_DG_Dataset_Types.html#css
But I don't know why I am getting this Error: Unknown dataset type.
I am creating a zip folder with this structure:
And the JSON file is this one:
Could you give me some ideas to fix my issue?
Thanks and regards.
I have attached an example with two images.
ChrisB_Intel
pramosg,
Check your json file name. You have it as dataset_meta_file.json, try dataset_meta.json
I just ran it and it seems to work fine.
Please let me know the results.
Chris
ChrisB_Intel
pramosg,
Chris
pramosg
Thanks @ChrisB_Intel,
The error is still there.  Anything else I should do?
pramosg
I also tried to use DL Workbench Intel DevCloud for Edge (JOB ID = 149731). Same issue. How does the system identify the dataset type?
pramosg
@ChrisB_Intel
The issue was solved. Instead dataset_file.json you mentioned I used try dataset_meta.json. And now the system recognizes the dataset type.
