Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1348 Discussions
Urgent: cannot compile and execute successfully for the same program after the server changed
Fernando_Mo
Has anyone met the problem as below when executed the program, however the program could compile and execute successful before the server changed of devcloud. In other word, for the same program, now it shows many errors after the server changed of devcloud.
it's so weird, would I need to configure anything else for it?
executed result:
                    Failed clGetDeviceIDs.
compiled result:
u154409@s005-n005:~/HLS_BLE/cpu$ make
g++ -c -DLINUX -O2 -g -I/glob/development-tools/versions/fpgasupportstack/d5005/2.0.1/inteldevstack/hld/host/include ble.cpp -o ble.o
g++ ble.o options.o opencl.o -L/glob/development-tools/versions/fpgasupportstack/d5005/2.0.1/inteldevstack/hld/host/linux64/lib -lOpenCL -o test_channels
ble.o: In function `init()':
/home/u154409/HLS_BLE/cpu/ble.cpp:64: undefined reference to `aocl_utils::getBoardBinaryFile(char const*, _cl_device_id*)'
options.o: In function `void std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<char const*>(char const*, char const*, std::forward_iterator_tag)':
/usr/include/c++/7/bits/basic_string.tcc:219: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_create(unsigned long&, unsigned long)'
options.o: In function `aocl_utils::Options::addFromCommandLine(int, char**)':
/home/u154409/HLS_BLE/cpu/options.cpp:61: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(char, unsigned long) const'
options.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::assign(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/7/bits/basic_string.h:1356: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_assign(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
options.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_check(unsigned long, char const*) const':
/usr/include/c++/7/bits/basic_string.h:302: undefined reference to `std::__throw_out_of_range_fmt(char const*, ...)'
options.o: In function `std::basic_istream<char, std::char_traits<char> >::basic_istream()':
/usr/include/c++/7/istream:607: undefined reference to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::basic_ostream<char, std::char_traits<char> >::basic_ostream()':
/usr/include/c++/7/ostream:385: undefined reference to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::basic_iostream<char, std::char_traits<char> >::basic_iostream()':
/usr/include/c++/7/istream:860: undefined reference to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o:/usr/include/c++/7/istream:860: more undefined references to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >' follow
options.o: In function `std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream(std::_Ios_Openmode)':
/usr/include/c++/7/sstream:704: undefined reference to `vtable for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::__cxx11::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >::basic_stringbuf(std::_Ios_Openmode)':
/usr/include/c++/7/sstream:101: undefined reference to `vtable for std::__cxx11::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_stringstream()':
/usr/include/c++/7/sstream:731: undefined reference to `vtable for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::__cxx11::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >::~basic_stringbuf()':
/usr/include/c++/7/sstream:65: undefined reference to `vtable for std::__cxx11::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::basic_iostream<char, std::char_traits<char> >::~basic_iostream()':
/usr/include/c++/7/istream:856: undefined reference to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::basic_ostream<char, std::char_traits<char> >::~basic_ostream()':
/usr/include/c++/7/ostream:93: undefined reference to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `std::basic_istream<char, std::char_traits<char> >::~basic_istream()':
/usr/include/c++/7/istream:104: undefined reference to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >'
options.o: In function `void aocl_utils::Options::set<bool>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool const&)':
/home/u154409/HLS_BLE/cpu/options.h:123: undefined reference to `std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_stringstream()'
opencl.o: In function `void std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<char const*>(char const*, char const*, std::forward_iterator_tag)':
opencl.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned long) const':
/usr/include/c++/7/bits/basic_string.h:2343: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(char const*, unsigned long, unsigned long) const'
opencl.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)':
/usr/include/c++/7/bits/basic_string.h:1258: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_append(char const*, unsigned long)'
opencl.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(char const*, unsigned long) const':
/usr/include/c++/7/bits/basic_string.h:2376: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(char const*, unsigned long, unsigned long) const'
opencl.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/usr/include/c++/7/bits/basic_string.h:1212: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_append(char const*, unsigned long)'
opencl.o:/usr/include/c++/7/bits/basic_string.h:1258: more undefined references to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_append(char const*, unsigned long)' follow
collect2: error: ld returned 1 exit status
make: *** [test_channels] Error 1
GM
JananiC_Intel
Thanks for posting in Intel forum.
Could you let us know which devcloud you are using(oneapi/fpga/edge)?
Janani Chandran
Fernando_Mo
Hi @JananiC_Intel
Thanks for your concern, now I am using the FPGA of Stratix 10 PAC for RTL, OpenCL.
Ganyong
Fernando_Mo
Hi @JananiC_Intel
Just now I tried it again, it's working again!!  Even if I didn't change anything in my program...
Anyway, thank you very much!
GM
JananiC_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
