I received this bash output when I ran a dl model with GPU (Cuda) on PyTorch-1.8.0.
Traceback (most recent call last):
File "/home/u93525/Documents/federated-learning-image-color/aswinvk28-colorization/demo_release.py", line 17, in <module>
colorizer_eccv16.cuda()
File "/home/u93525/.local/lib/python3.9/site-packages/torch/nn/modules/module.py", line 680, in cuda
return self._apply(lambda t: t.cuda(device))
File "/home/u93525/.local/lib/python3.9/site-packages/torch/nn/modules/module.py", line 570, in _apply
module._apply(fn)
module._apply(fn)
File "/home/u93525/.local/lib/python3.9/site-packages/torch/nn/modules/module.py", line 593, in _apply
param_applied = fn(param)
File "/home/u93525/.local/lib/python3.9/site-packages/torch/nn/modules/module.py", line 680, in <lambda>
File "/home/u93525/.local/lib/python3.9/site-packages/torch/cuda/__init__.py", line 214, in _lazy_init
torch._C._cuda_init()
RuntimeError: Found no NVIDIA driver on your system. Please check that you have an NVIDIA GPU and installed a driver from http://www.nvidia.com/Download/index.aspx
In one of the articles, it is mentioned you can run CUDA NVIDIA on Intel GPUs, so why is an error thrown to the console in this case?
Reference Article:
https://hothardware.com/news/cuda-on-intel-gpus-zluda
Would you kindly advise?
This is duplicate to
https://community.intel.com/t5/Intel-DevCloud/has-intel-Devcloud-installed-CUDA/td-p/465604
Thank you for posting in Intel Forums.
We are sorry to inform you that Devcloud does not support CUDA. Only DPCPP and SYCL codes are supported by Intel GPUs. As this is a duplicate thread of https://community.intel.com/t5/Intel-DevCloud/has-intel-Devcloud-installed-CUDA/td-p/465604 and the query is answered in the same one, Can we discontinue monitoring this thread ?
Raeesa
Thank you.
Thank you for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Raeesa
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
