Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Using FP16&FP32
lqxqxl
  The '.bin' files provided from the samples is not 'UTF-8' encoded.
Just saving disable.
Hari_B_Intel
Hi lqxqxl,
Thank you for posting your question in the Intel community,
Are you using Intel DevCloud for the edge?
The model squeezenet1.1 you are using is based on data-type FP16 and FP32. To run an application in Intel DevCloud for the edge, we encourage the user to use JupyterLab to execute the command rather than Terminal due to the virtual environment difference.
On the main page, click on JupyterLab
Hope this information help
Thank you
Hari_B_Intel
Hi lqxqxl,
Thank you
Hari_B_Intel
Hi lqxqxl
This thread will no longer be monitored since we have provided a solution. Please submit a new question if you need any additional information from Intel.
