Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1695 Discussions
VTune EMON Collector Message: ERROR
TestDR1
I get errors below when I used VTune in the devcloud
vtune: Error: EMON Collector Message: ERROR - A collection is already in progress - Abort current run.
vtune: Error: EMON Collector Message: PMU resource(s) currently being used by another profiling tool or process: another PMU collection session may be running
vtune: Collection failed.
vtune: Internal Error
Can we run VTune profiler in the DevCloud?
I followed the intel VTune example at oneAPI_Essentials/06_Intel_VTune_Profiler
AthiraM_Intel
We were unable to reproduce the issue that you mentioned from our side. We were able to successfully run the VTune example from oneAPI_Essentials/06_Intel_VTune_Profiler/ without any error.
Please see the below screenshot:
Could you please try copying the original notebook from the data directory of Intel DevCloud for oneAPI to your present directory by running the below command so that there are no changes to the original notebook:
cp /data/oneapi_workshop/oneAPI_Essentials/06_Intel_VTune_Profiler .
Once this is done, confirm if it is working fine. If the issue still persists please share the results after running the cells and the screenshot of the error.
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
