Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1661 Discussions
VTune passphrase reset doesn't work
RonD
I forgot my vtune passphrase
so I tried to start the server with this command:
vtune-backend --web-port=55001 --enable-server-profiling --reset-passphrase
I get the URL with the one-time-token=...
but when entering the URL I get the normal enter menu.
Ron
JaideepK_Intel
We ran vtune-backend from our side, and the reset passphrase works fine for us.
The reason it is not asking for a password/passphrase is that you may have already opened the URL in another tab or window (you already authenticated). Just kill the process on DevCloud (also close all the vtune-backend tabs) and try to run the backend command once again.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
Jaideep
RonD
It doesn't fix the problem.
Even if all processes killed the problem continued
RonD
I tried again today the same way and it worked I don't know what changed but thanks for the help
Ron
JaideepK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
