Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1527 Discussions
Vanilla tensorflow vs Intel optimized tensorflow
Girin
Training a model using the MNIST dataset with TF and Keras on the DevCloud, and noticing that performance with Vanilla TF is much faster when compared to Intel optimized TF.
1 . Installed vanilla TF using 'pip install tensorflow'. This installed TF 2.3.1. Selected Python 3.7 kernel. Training takes ~2s/epoch.
2. Installed Intel optimized TF with 'pip install intel-tensorflow-avx512'. Installed TF 2.3.0. Selected Python 3.7 kernel. Training takes ~10-15s/epoch.
Tried this multiple times. Similar results. Any idea why?
ArunJ_Intel
Hi Girin,
The out of box performance of intel tensorflow might not be always better than the stock tensorflow. To leverage performance improvement with intel tensorflow you should set a few environment variables and few minor code changes would be required.
Environment variables
Set KMP_BLOCKTIME=1,OMP_NUM_THREADS={number of cpu cores in your compute node}(you could get this by using lscpu command)
eg:
export KMP_BLOCKTIME=1
export OMP_NUM_THREADS= #physical cores
export KMP_AFFINITY=granularity=fine,verbose,compact,1,0
Code
Also set the inter_op_parallelism_threads to a value 2. This can be set adding the below line in your code.
tf.config.threading.set_intra_op_parallelism_threads(
  2
Please refer to more BKMS and recommended settings when using intel tensorflow at below link
https://software.intel.com/content/www/us/en/develop/articles/maximize-tensorflow-performance-on-cpu-considerations-and-recommendations-for-inference.html
Please try out the above steps and let us know if you are still having issues.
Arun Jose
ArunJ_Intel
Hi Girin,
eg:
Code
  2
Arun Jose
Girin
great, thanks for this Arun. With these settings, i now get a training speed of ~1s/epoch with the MNIST dataset and intel optimized tensorflow on the DevCloud
ArunJ_Intel
Hey Girin,
Glad to know the solution provided helps. We wouldn't be monitoring this thread further. Please feel free to raise a new thread in case of further issues.
Arun
