Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1527 Discussions
Welcome.ipynb Documentation Defects
User01
New Contributor II
When using "Launch JupyterLab" from https://devcloud.intel.com/oneapi/get_started/ a JupyterLab instance is started, and a "Welcome.ipynb" Notebook is visible from the root of the JupyterLab File Browser. An initial read-through reveals at least the following defects in the content:
"By using the Intel DevCloud for oneAPI Projects, you are agreeing to the following terms linked in the footer of the Intel DevCloud website:
https://devcloud.intel.com/oneapi/" - The terms linked in the footer of that page are for Colfax and Intel.com. DevCloud has its terms, which are not listed on that page.
"The error stream goes to the .e* files. For our job, it contains the Python version (not because we had an error, but because Python chooses to write the version to the error stream):" - The error file is empty. Perhaps this statement was true at some point, but not with "Python 3.9.7 :: Intel Corporation," which does not write the version to the stderr.
Rahila_T_Intel
Thanks for reporting this issue. We were able to reproduce it and we have informed the development team about it.
Rahila_T_Intel
Thank you for your feedback. We have provided your feedback to the relevant team. At this moment there is no visibility when it will be implemented and available for use.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
