Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1726 Discussions
What is password for Tiny Virtual Machine via SSH Command ?
ZeeiDev
Good Morning
this is my first time for using Tiny Virtual Machine via SSH Command
But when i'm try to connect visa SSH command
always asking for password?
Cloud you help me
Thank you
ssh -J guest@146.152.226.xx -L 10022:10.1.79.xx:22 ubuntu@10.1.79.xx
The authenticity of host '146.152.226.xx (146.152.226.xx)' can't be established.
ECDSA key fingerprint is SHA256:yI1eGvLTKfCCpuX7my+UFyrU041ZJM/i+0kGKYhFUn0.
Are you sure you want to continue connecting (yes/no/[fingerprint])?
Warning: Permanently added '146.152.226.xx' (ECDSA) to the list of known hosts.
Password:
Password:
Password:
guest@146.152.226.xx: Permission denied (publickey,keyboard-interactive).
kex_exchange_identification: Connection closed by remote host
Megat_Intel
Hi ZeeiDev,
Thank you for your patience.
Are you trying to connect to the instance using WSL? If yes, then you need to regenerate a new SSH key in WSL and launch a new Virtual Machine instance.
On the other hand, If you are not using WSL. We advise you to re-generate a new SSH Key. The public key must be in your profile before starting an instance. Then, you should be able to launch the Virtual Machine instance straight to the welcome screen without needing any password. You can refer to the steps below:
  1. Setup the SSH Key again
  2. Open and copy the entire content of the file: id_rsa.pub.
  3. Update the copied SSH key in the profile before starting an instance.
  4. Terminate the old Virtual Machine instance.
  5. Launch a new Virtual Machine instance.
Megat
Rahila_T_Intel
Could you please let us know whether you're using Intel DevCloud? If yes, which devcloud are you using? Is it DevCloud for oneAPI/ DevCloud for Edge/FPGA/DevCloud for Beta?
ZeeiDev
Megat_Intel
Hi ZeeiDev,
Megat
Megat_Intel
Hi ZeeiDev,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Megat
