If for example I want to install Go(lang) with Conda using the file named install_golang.sh that I created which contains the following:
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
conda install -c conda-forge go
Where does it put the installed binary?
Also, I submit the command using qsub with:
qsub -l nodes=1:gpu:ppa=2 -d . install_golang.sh
I guess that I have to manually set the PATH environment variable to locate the installed Go binaries after the package was installed as there is no Environment Variables sharing.
Thanks for any hint/help.
Thank you for reaching out. You can find the binaries in the conda folder of the environment you’re working in.
> To find the path, follow the below steps.
conda env list //lists the paths of conda environments
>Path to find the binaries
cd ~/.conda/envs/<environment_name>/bin
OR
cd /home/uXXXXX/.conda/envs/<environment_name>/bin
And to submit the job, please execute the below step.
conda activate <environment_name> //Activate the required environment
qsub -l nodes=1:gpu:ppn=2 -d . install_golang.sh //ppn instead of ppa where ppn is process per node
To know more about job submission in devcloud, please refer: https://devcloud.intel.com/oneapi/documentation/job-submission/
> No need to set the PATH. After activating the conda environment where the packages are installed, the environment variables will be set automatically. Executing which go, displays the same path
$ which go
/home/uXXXXX/.conda/envs/<environment_name>/bin/go
Hope this helps
Gopika
We have not heard from you. Has the solution provided helped? Can we discontinue monitoring this thread?
Gopika
We have not heard back from you, so we will close this inquiry now. If you need further assistance, please post a new question.
Gopika
