Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1467 Discussions
Windows SCP unsuccessful file transfer
fgalindo
I'm fairly new to devcloud and I haven't been able to transfer files from my devcloud to my local machine (Windows).
I've tried running this command using both cmd and visual studio code :
scp devcloud:~/my_file .
But all I get is "ssh: connect to host ssh.devcloud.intel.com port 22: Connection timed out"
What am I doing wrong or missing?
AlekhyaV_Intel
Thank you for posting in Intel Communities. Please make sure that you're not connected to proxy while running this command. There is another option where you can download/upload files in devcloud. You can use Jupyter Notebook.
Downloading files from DevCloud using Jupyter Notebook:
1) Right-click on a file & click on Download option as shown below:
Uploading files to DevCloud using Jupyter Notebook:
1) You can upload any files by clicking upload button:
If this resolves your issue, make sure to accept this as a solution. This helps others with similar issue. Thank you.
Alekhya
Alekhya
AlekhyaV_Intel
Alekhya
Alekhya
fgalindo
Hello Alekhya,
Thank you for replying. I tried your solution with Jupyter Notebook and it worked well.
On a second note, powershell and cmd did not work for me and that's the reason I posted this question, but then I tried with Cygwin and I was able to transfer files with no problem!
Fabian
AlekhyaV_Intel
Thank you for accepting our solution. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
