Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1467 Discussions
You are already logged into node s005-n009: interactively.
well
How to login into new node when it says You are already logged into node s005-n009: interactively.
RaviranjanK_Intel
Could you please check whether there is any running jobs by using the command "qstat"
If there is any, please kill the process using the command "qdel <job ID>" . You will get the job ID from the qstat view.
You can use the command "logout" to exit from the compute node. Again use the command "qsub -I" to enter into a new compute node.
Also you can use the jupyter lab. To access DevCloud using jupyter lab, please follow the below steps:
Go to the link: https://devcloud.intel.com/oneapi/get_started/
At the end of the page, Under Connect with Jupyter* Lab, click on Launch JupyterLab*.
After launching the jupyterLab follow below path.
File--> New --> Terminal, you will get a terminal with compute node.
If the issue still persists, please share the steps to reproduce the issue and the screenshot of the error.
Raviranjan
RaviranjanK_Intel
Raviranjan
RaviranjanK_Intel
We haven't heard back anything from you. Could you please confirm if the issue is resolved.
well
Yes this problem is solved. Thank you very much intel
RaviranjanK_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
