Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1055 Discussions
arria 10 won't work [ devcloud implementation fails]
AVolo2
Hi Guys
How is it going?
I am trying to get through https://github.com/intel/FPGA-Devcloud/tree/master/main/QuickStartGuides/OpenCL_Program_PAC_Quicksta...
But first it fails to locate the setup tools, then after sourcing the environment manually still  third execution fails
aoc device/hello_world.cl -o bin/hello_world_fpga.aocx -board=pac_a10
aoc: Running OpenCL parser....
aoc: OpenCL parser completed
aoc: Linking Object files....
aoc: Optimizing and doing static analysis of code...
aoc: First stage compilation completed successfully.
aoc: Compiling for FPGA. This process may take several hours to complete.  Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets.  If the reports indicate performance targets are not being met, code edits may be required.  Please refer to the Intel FPGA SDK for OpenCL Best Practices Guide for information on performance tuning applications for FPGAs.
Error (23035): Tcl error:
Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings
Error: Compiler Error, not able to generate hardware
we also got a local arria 10gx  PAC which was not possible to get running up to a point where hello world example works. But at the devcloud it neither works up to the hello world example. So far only up to the point below which passes
aocl diagnose
BoonBengT_Intel
Hi @AVolo2,
Thank you for posting in Intel community forum and hope all is well.
To clarify, are you saying that when you run the tools_setup command it is failing?
On which node are you connected to in the devcloud?
Suspecting that they might be some node anomaly which is causing error.
U have managed to try the mention steps to perform a tools_setup and aocl diagnose and diagnostic passed.
Hence would recommended maybe to try another node or node s005-003.
Hope to hear from you
Best Wishes
BB
AVolo2
Thank you for following up!
Q.1 : "To clarify, are you saying that when you run the tools_setup command it is failing?"
A.1:There is no setup_tools alias in bach terminal unfortunately
I have to source environment manually
Q2. "On which node are you connected to in the devcloud?"
) Enter Specific Node Number
Number: 1
Which Arria 10 PAC Development Stack release would you like to source?
0) 1.2
1) 1.2.1
Number: 1
running: qsub -q batch@v-qsvr-fpga -I -l nodes=s005-n003:ppn=2
qsub: waiting for job 33988.v-qsvr-fpga.aidevcloud to start
qsub: job 33988.v-qsvr-fpga.aidevcloud ready
# Resources:           neednodes=s005-n003:ppn=2,nodes=s005-n003:ppn=2,walltime=06:00:00
How do I switch to try another node or node s005-003? what are nodes available how to try them?
AVolo2
any ideas
now it got to another issue
can it be because fpga compilation [ that takes long got ssh to devcloud abruption]? else?
BSP Diagnostics
Device Name:
acl0
BSP Install Location:
/opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp
Vendor: Intel Corp
Physical Dev Name   Status            Information
pac_ee00000         Uninitialized     OpenCL BSP not loaded. Must load BSP using command:
                                      'aocl program <device_name> <aocx_file>'
                                      before running OpenCL programs using this device
DIAGNOSTIC_PASSED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
u155004@s005-n002:~/A10_OPENCL_AFU/hello_world/bin$ aocl program acl0 hello_world_fpga_unsigned.aocx
aocl program: Running program from /opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
Program succeed.
u155004@s005-n002:~/A10_OPENCL_AFU/hello_world/bin$ ./host
Querying platform for info:
CL_PLATFORM_NAME                         = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR                       = Intel(R) Corporation
CL_PLATFORM_VERSION                      = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4
Querying device for info:
CL_DEVICE_NAME                           = pac_a10 : Intel PAC Platform (pac_ee00000)
CL_DEVICE_VENDOR                         = Intel Corp
CL_DEVICE_VENDOR_ID                      = 4466
CL_DEVICE_VERSION                        = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4
CL_DRIVER_VERSION                        = 19.4
CL_DEVICE_ADDRESS_BITS                   = 64
CL_DEVICE_AVAILABLE                      = true
CL_DEVICE_ENDIAN_LITTLE                  = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE          = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE      = 0
CL_DEVICE_GLOBAL_MEM_SIZE                = 8589933568
CL_DEVICE_IMAGE_SUPPORT                  = false
CL_DEVICE_LOCAL_MEM_SIZE                 = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY            = 1000
CL_DEVICE_MAX_COMPUTE_UNITS              = 1
CL_DEVICE_MAX_CONSTANT_ARGS              = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE       = 2147483392
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS       = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN            = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE       = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR    = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT   = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT     = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG    = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT   = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE  = 0
Command queue out of order?              = true
Command queue profiling enabled?         = true
Using AOCX: hello_world.aocx
Context callback: Malformed program binary: missing .acl.board section
Context callback: kernel argument info is not available
Context callback: Invalid binary
ERROR: CL_INVALID_BINARY
Failed to create program with binary
qsub: job 33996.v-qsvr-fpga.aidevcloud completed
AVolo2
seems I got through
thanks
but it is faulty at the another issue listed above
AVolo2
unfortunately connection seems to interrupt every time I am trying to run this step
so ifthe output is broken or not I am not certain
if it is that may be the cause of the next mentioned ahead step failing
client_loop: send disconnect: Broken pipe
AVolo2
then without integrity check I could execute further steps but it fails on the step of executing ./host as you may see from posts above
 source $AOCL_BOARD_PACKAGE_ROOT/linux64/libexec/sign_aocx.sh -H openssl_manager -i hello_world_fpga.aocx -r NULL -k NULL -o hello_world_fpga_unsigned.aocx
The script assumes the PACsign and Intel Acceleration Stack environment is setup. If not run the command : <stack_installation_path>/init_env.sh
hsm_manager=openssl_manager
aocx filename/path=hello_world_fpga.aocx
root_public_key=NULL
csk_public_key=NULL
output filename/path=hello_world_fpga_unsigned.aocx
null=1
openssl hsm_manager_options=openssl_manager
input path =.
input filename =hello_world_fpga.aocx
output path =.
output filename =hello_world_fpga_unsigned.aocx
Extracted the filename as hello_world_fpga_unsigned
1. Extracted the bin from the aocx
2. Extracted the gzip compressed GBS file from the .bin
gzip: temp_hello_world_fpga_unsigned.gbs already exists; do you wish to overwrite (y or n)? y
3. Uncompressed .gz it to get the GBS file
Initiating PACSign tool to sign the GBS. This process will take a couple of minutes...
Creating unsigned aocx file by signing a NULL key
No root key specified.  Generate unsigned bitstream? Y = yes, N = no: Y
No CSK specified.  Generate unsigned bitstream? Y = yes, N = no: Y
4. Signed the GBS
gzip: signed_hello_world_fpga_unsigned.gbs.gz already exists; do you wish to overwrite (y or n)? y
5. Compressed the gbs file
6. Added the signed gzip file to fpga.bin
7. Added the fpga.bin file back into aocx file
The signed file hello_world_fpga_unsigned.aocx has been generated. Use the command aocl program <device_name> <filename>.aocx to program it on the FPGA card
AVolo2
so the question is how to confirm the command resulted in success given during its execution connectivity always gets lost ?
AVolo2
seems it worked;
it is the hello-world example, right?
~/A10_OPENCL_AFU/hello_world/bin$ ./host        Querying platform for info:        ==========================        CL_PLATFORM_NAME                         = Intel(R) FPGA SDK for OpenCL(TM)                                                   CL_PLATFORM_VENDOR                       = Intel(R) Corporation                                                               CL_PLATFORM_VERSION                      = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4        Querying device for info:        ========================        CL_DEVICE_NAME                           = pac_a10 : Intel PAC Platform (pac_ee00000)                                         CL_DEVICE_VENDOR                         = Intel Corp        CL_DEVICE_VENDOR_ID                      = 4466        CL_DEVICE_VERSION                        = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4                          CL_DRIVER_VERSION                        = 19.4        CL_DEVICE_ADDRESS_BITS                   = 64        CL_DEVICE_AVAILABLE                      = true        CL_DEVICE_ENDIAN_LITTLE                  = true        CL_DEVICE_GLOBAL_MEM_CACHE_SIZE          = 32768        CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE      = 0        CL_DEVICE_GLOBAL_MEM_SIZE                = 8589933568        CL_DEVICE_IMAGE_SUPPORT                  = false        CL_DEVICE_LOCAL_MEM_SIZE                 = 16384        CL_DEVICE_MAX_CLOCK_FREQUENCY            = 1000        CL_DEVICE_MAX_COMPUTE_UNITS              = 1        CL_DEVICE_MAX_CONSTANT_ARGS              = 8        CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE       = 2147483392        CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS       = 3        CL_DEVICE_MEM_BASE_ADDR_ALIGN            = 8192        CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE       = 1024        CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR    = 4
BoonBengT_Intel
Hi @AVolo2,
Good to know that you managed to get it work, for the clarification that you mention previously below are the answer for them:
1) how to confirm the command resulted in success
  A> By doing a batch submission on the steps #4 in the link you have above, that would output the log into 2 seperate files which will help to us understand the compilation even if connection timeout.
2) it is the hello-world example
  A> Yes you are right.
Hope that clarify your doubts.
Best Wishes
BB
BoonBengT_Intel
Hi @AVolo2,
Greetings, as we do not receive any further clarification on what is provided, and challenges are overcome previously, we will no longer monitor this thread. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
AVolo2
@BoonBengT_Intel
today I noticed that devcloud won't work anymore after the server signature got changed;
It won't let to connect to a node.
How to do it? given the problem is that user got lost group association for access to PAC node
BoonBengT_Intel
Hi @AVolo2,
Apologies to hear that, however from my end I am still able to connect to devcloud.
Per understanding, there is a recent SSH server changes in the devcloud.
And steps has been mention in the email on what to perform and expect.
However if you are still having issues still persist and you are not able to connect to devcloud, would suggest to drop a note in the thread below, and our team will get back to you as soon as possible.
- https://community.intel.com/t5/Intel-DevCloud/Announcement-Changes-to-SSH-Server-on-DevCloud/m-p/139...
Cheers
Best Wishes
BB
AVolo2
@BoonBengT_Intel
However, the problem is not that I can not connect to the devcloud with the updated signatures,
But that it lost access to the [1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL]
after the update due to the fact the user doesn't seem to have group association for 10 GX RTL AFU access.
Can you access the node s005-n007
ssh -L 4002:s005-n007:22 devcloud
running: qsub -q batch@v-qsvr-fpga -I -l nodes=s005-n007:ppn=2
qsub: submit error (Unauthorized Request  MSG=group ACL is not satisfied: user u155004@login-2.aidevcloud, queue batch)
AVolo2
@BoonBengT_Intel
Could you also extend on the batch submission, please?
Because the step from the link above section 4 won't work
  A> By doing a batch submission on the steps #4 in the link you have above, that would output the log into 2 seperate files which will help to us understand the compilation even if connection timeout."
u155004@login-2:~$ devcloud_login -b A10PAC 1.2.1 A10_v1.2.1_opencl_batch.sh
qsub: script file 'A10_v1.2.1_opencl_batch.sh' cannot be loaded - No such file or directory
AVolo2
@BoonBengT_Intel The issue with node access has been resolved with help of Intel folks who addressed the permission issue
However I wasn't able to figure out how to use the reference example to run the batch submission
AVolo2
@BoonBengT_Intel could you extend on the batch submission exampl, please?
BoonBengT_Intel
Hi @AVolo2,
Greetings and apologies for the delayed in response.
For the mention on the previous issues where having some challenge running example design seems to be overcome and currently there are another issues on the devcloud account related I am suspecting.
I am seeing a similar thread below on the issues hence lets continue our discussion there.
https://community.intel.com/t5/Intel-DevCloud/arria-10-won-t-work-devcloud-implementation-fails-2-co...
And we would marked this thread as closed, please do let us know if there is any concern there.
Best Wishes
BB
