Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1652 Discussions
autosklearn install crashes
JohnWestlund
I've installed autosklearn locally using:
pip install auto-sklearn
But I get the following error whenever I try and use the fit function:
import autosklearn
import autosklearn.classification
#define the model
automl = autosklearn.classification.AutoSklearnClassifier(time_left_for_this_task=1200, n_jobs=1)
#train the model
automl.fit(features_train, target_train)
This is the error:
[ERROR] [2022-12-05 14:38:09,724:Client-AutoML(1):63847a06-74ed-11ed-b04d-5dc3c51ac30b] (' Dummy prediction failed with run state StatusType.CRASHED and additional output: {\'traceback\': \'Traceback (most recent call last):\\n  File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/evaluation/__init__.py", line 397, in run\\n    obj(**obj_kwargs)\\n  File "/home/u157922/.local/lib/python3.9/site-packages/pynisher/limit_function_call.py", line 302, in __call__\\n    tmp_dir.cleanup()\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 834, in cleanup\\n    self._rmtree(self.name)\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 816, in _rmtree\\n    _shutil.rmtree(name, onerror=onerror)\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 740, in rmtree\\n    onerror(os.rmdir, path, sys.exc_info())\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 738, in rmtree\\n    os.rmdir(path)\\nOSError: [Errno 39] Directory not empty: \\\'/home/u157922/tmp/tmpl7sxjn6a\\\'\\n\', \'error\': "OSError(39, \'Directory not empty\')"}.',)
  File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/automl.py", line 765, in fit
    self._do_dummy_prediction()
  File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/automl.py", line 489, in _do_dummy_prediction
    raise ValueError(msg)
ValueError: (' Dummy prediction failed with run state StatusType.CRASHED and additional output: {\'traceback\': \'Traceback (most recent call last):\\n  File "/home/u157922/.local/lib/python3.9/site-packages/autosklearn/evaluation/__init__.py", line 397, in run\\n    obj(**obj_kwargs)\\n  File "/home/u157922/.local/lib/python3.9/site-packages/pynisher/limit_function_call.py", line 302, in __call__\\n    tmp_dir.cleanup()\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 834, in cleanup\\n    self._rmtree(self.name)\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/tempfile.py", line 816, in _rmtree\\n    _shutil.rmtree(name, onerror=onerror)\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 740, in rmtree\\n    onerror(os.rmdir, path, sys.exc_info())\\n  File "/opt/intel/inteloneapi/intelpython/latest/lib/python3.9/shutil.py", line 738, in rmtree\\n    os.rmdir(path)\\nOSError: [Errno 39] Directory not empty: \\\'/home/u157922/tmp/tmpl7sxjn6a\\\'\\n\', \'error\': "OSError(39, \'Directory not empty\')"}.',)
 I've tried clearing out the 'tmp' directory -- but that does not resolve or change the error.
JaideepK_Intel
I hope you are doing well.
Attaching workaround notebook for your reference. If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We were able to reproduce your issue from our end, we are working on this internally and get back to you with an update.
Jaideep
JohnWestlund
Thanks Jaideep. I appreciate the quick response.
JohnWestlund
Looks like something was modified in my environment because auto-sklearn was working today. I then tried to add PipelineProfiler:
pip install PipelineProfiler
And now auto-sklearn is broken again.
Ideally, both would be available by default. But at a minimum, I'd like to understand the steps to install and use them successfully.
JohnWestlund
@JaideepK_Intel Hope all is well. Curious if there is an update on this issue. Thanks!!
JaideepK_Intel
Sorry for the delay. We are going to contact you privately via mail. Have a great day ahead.
Jaideep
JaideepK_Intel
Good day to you,
We are going to contact you privately.
Jaideep
JaideepK_Intel
Good day to you.
As your issue is resolved can we close this thread?
Jaideep
JohnWestlund
Hi @JaideepK_Intel ,
Can we get the resolution posted on the forum for other people to see?
Best,
John
JaideepK_Intel
We are working with the Dev team, Soon we will update with an additional comment and add the notebook file.
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
